snow+no turning+curb= driver side front axle broke?
Old Jan 20, 2005 | 01:10 PM
95nissanMax's Avatar
well i was turngin into a parking lot off a pretty main road and well once i hit the snow the car wouldnt turn. so i put on the brakes and kept turning(my mistake) and i hit the curb.(with the wheels turned) and so now im wodering what kind of damage can i expect..? i know MY NEW! strut is blown by the "smoke" gas that was comming from the wheel. and im guessing the axle is broke. the wheel is slightly slanted. lemme know what you think the damage is and/or how much to fix it. PLEASE HELP.
Old Jan 20, 2005 | 01:17 PM
MDeezy's Avatar
glad to hear your ok.
best bet is to take off the wheel and inspect.
but how fast were you going?
could be broken axle
bent control arm
bent rim
not sure what to expect to fix but be prepaired to shell out some money, dont know if you can find 1 replacement struts but look around and ebay you might get lucky.
Old Jan 20, 2005 | 01:35 PM
not fast i know i dont have a bent rim... but im thinking maybe the control arm is wackeed too. also i just saw a pool of oil? right behind my tire furthering my suspisions about the strut. which i can buy ONE of so thats good.
Old Jan 20, 2005 | 01:36 PM
Adrian112597's Avatar
Adrian
This happened today? Almost happened to me on the way to work too! Sorry to hear that.
Old Jan 20, 2005 | 01:46 PM
MDeezy's Avatar
their is nothing oily on the driver side, ( I dont think ) how is the car sitting? doe that side with the blown strut sit lower? ty pushing down on it and see how it bounces back, thant could help confirm a blown strut.
oh damn you in IL so Its probably waaaay too cold (duhh you said in the snow) to pull off the wheel and check it out, did you drive home? or get it towed?
Old Jan 20, 2005 | 01:58 PM
Dagger969's Avatar
My roommate just did this to his car. He was turning, lost traction, kept the wheel turned, nailed the curb flush and fuked his car up. Turned out he broke the control arm, the strut bar, the wheel was demolished, pushed the wheel so far back it destroyed the rocker panel. The only thing that seemed to be ok was the cv joint and the strut but those were replaced to be on the safe side. Hope you make out ok on this, good luck
Old Jan 20, 2005 | 02:15 PM
yea today. so now im guessing the strut $40 and the control arm.? anyone know costs for this?
Old Jan 20, 2005 | 02:39 PM
MDeezy's Avatar
check www.car-part.com they should have some dont know the price but they should be the cheapest.
then local jnk yards, then org memebers. or PM exit10 he as somewhat of the same thing happen to him and he had a bent control arm.
Old Jan 20, 2005 | 03:30 PM
thanks a bunch MDeezy! anyone else know anything bout this plz help.
Old Jan 20, 2005 | 03:34 PM
exit10's Avatar
same thing happened 2 me but everyone flamed me. i hit the curb at about 4mph and this is what was broken in my car
axle
control arm
bent rim REALLY bad (cuz i went 2 get it balanced and they said the rim was too bent)
front struts
wheel bearing.
if you hit just as slow as me i gurantee you everything is completly effed up, your car will prolly never drive the same again... mine doesnt. my totall repair cost was about 700 bucks. i kinda got ripped on the struts tho i got 2 kyb gr2's for 250 installed, def. get 2 new front ones. the control arm installation i also got ripped for 200 for the new arm plus installation. then i paid for an alignment, a new axle and new wheel bearing. also towing was 100 bucks for me.
i knew my accident would come in handy.... Im me on AIM > gettcrunnkkked
Old Jan 20, 2005 | 04:49 PM
Ant96GLE's Avatar
Not laughing at your misfortune of your car... just your luck on here after they flamed you.
What to check and inspect that might have been broken or damaged...
Axles
control arms
sway bar links
strut
damaged wheel bearing
Old Jan 20, 2005 | 05:25 PM
thanks everyone for the info.
Old Jan 20, 2005 | 10:08 PM
tranz's Avatar
gosh i just bent my rim today too freging bounced off a curb, its Rashed and a bit bent, Wah, what should i do get it balanced?
Old Jan 21, 2005 | 07:27 AM
MDeezy's Avatar
a wheel shop should be able to fix and balance it back for you.
Old Jan 21, 2005 | 11:49 AM
tranz's Avatar
ah thanks Mdeezy
Old Jan 24, 2005 | 04:12 PM
well i found out the left lower control arm is totaly bent! so does anyone know where to get a good price on one and how to get that control arm off?? any help is good help.
Old Jan 24, 2005 | 04:15 PM
MDeezy's Avatar
ah thanks Mdeezy
no prob
www.car-part.com
www.jerryromenissan.com -new but probably more costly
as for how to, if you have the haynes manual it should have something on it, I'm sure someone on here has the info a few people have done it lately, or period and can tell you
rtirbany
Sep 8, 2015 11:46 AM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
BassAddictJ
Aug 4, 2015 11:38 AM
