Coolant leak, need someone to identify this hose..
Okay so one morning I decided to check my coolant tank just becuz.....and I noticed it was alot lower than usual.....I thought that was weird so I just added disstilled water and brought it back to spec.....then I tore apart my stock airbox to install my BERK/APEX-I and found this.....
See the red coolant on those hoses? Can anybody identify this hose? I have no idea where this leads to....and do any other 2k2 owners have this problem too? Btw this is near the tranny area right below the BERK midpipe area.....someone please identify this hose for me so I can replace it and how much this part will cost...Thanks!
Not sure what it is because I can't see where it goes to. If it terminates into the firewall then it should be a heater hose. Without having my engine bay in front of me for reference, typically, you have 4 main hoses: Upper Radiator, Lower Radiator, Heater In and Heater Out. Someone who has messed around with the hoses before will have to keep me straight.
No u guys have it all mixed up....that is my COOLANT becuz I changed my coolant to TOYOTA REDS....not NISSAN GREENS (factory coolant)
and No its nothing related to the transmission becuz my tranny fluid looks brownish,black just like engine oil.....
The hose i'm talkin bout is in the middle of the picture, not where my hand is at.....can u see the red fluid on those two hoses? For reference this pic is located near the transmission/intake area (drivers side).....are they really the heater hoses?
Originally Posted by spddracer
Tap water and yes it is your heater hose
yes those are heater hoses. wash off the coolant and look to see if there is a crack in the hose somehwere
Tap water huh? From what I learned in automotive class tap water contains many different particles/minerals that could contaminate the radiator system....and disstilled water is pure H20 which has no minerals or particles except h20, making it safe to run in the radiator....correct me if i am wrong...
are you sure the new coolant is compatible with a nissan cooling system??
Sorry, I also thought you were talking about the hose in your hand.
Yes I am sure its compatible....Theres a whole article on it in the FLUIDS & LUBRICANT section on the .org.......
And if Nissan Recommends tap water.....what is so wrong about running disstilled? Not enuff minerals or something? From what I learned, its not good to be running all that crud inside your radiator system....
btw thanks for all your inputs!
distilled water is acidic, not neutral. The problem is that distillation in increases the ionic content of water by removing the disolved salts and impurities. Although stilll very dilute, distillation frees up more hydroxide and hydronium ions that would normally be bound to these disolved salts in less "pure" water. This makes distilled water more corrosive than say, "bottled" water at the grocery store.
I dont think it really matters. I have never had a problem using tap water.
I guess I should say you dont have to use distilled water. My thoughts are,
Originally Posted by soonerfan
nissan recommends tap water
Since when did plain old water have an acidic pH? I think you need to review your high school chemistry. The definition of a pH of 7, or completely neutral, is plain old, distilled water. What makes a liquid acidic or basic is the concentration of hydrogen ions to hydroxide ions. Distilled water has an equal number of each, giving you a neutral pH. Besides, when mixed with equal parts of antifreeze, which contains salts, that should take care of any of the issues with free ions. Hence the recommendation of running a 50/50 mixture of water and antifreeze. It's not only for the extended liquid temperature range. I don't know what your water is like, but if you live somewhere like Wisconsin, you will have a ton of iron and calcium in the water. Very bad for your cooling system. Do a little more thinking about what you are saying. A little knowledge is dangerous.
SALT corrodes aluminum! It is good if, as you say, the salt is removed during distillation.
Distilled water is PURE water..... without extra junk dissolved in it.
litch
123
Jan 4, 2024 07:01 PM
foodmanry
Sep 24, 2015 12:02 PM
