max owners with 2k4 irotors.
Hey Semy2k2go, you put in 2k4 rotors onto your 5.5 gen??? Are they a direct fit? Did you have problems with clearence? Are they better in stopping power? Sorry for all the questions, but I needed to replace my brakes soon. Was looking at regular slotted/cross drilled from Brembo, but 2k4 rotors are suppose to be better. Was wondering how it is on ur's
Originally Posted by maxspeed96CT
wait 2k4 rotors are a dirrect swap for you?
are they larger, do they require new calipers?
i'm buying the blemh kit. I already have the TTZ calipers sitting in my garage. I just need the rotors and the relocation kit from matt.
Sorry to whoe the thread, but doesnt anyone know if there is any diffrance between 4th gen and 5th gen brake calipers?
I want to upgrade to 24k rotors but im not sure if i need 2k rotors
The brake pad part numbers for hawk brake pads are the same...
interesting. if they are a direct swap, i will get me a pair for the front.
Semy2k2go, where did you get a pair made for the 2k2-2k3 maxima? are they the same size as the 2k2-2k3 rotors or the same size as 2k4 and up rotors cause arent 6th gen maxima rotors bigger?
Tim
front calipers are the same from 89-99.
They got slightly larger in 2000-2001.
slightly larger again in 2002-2003.
Even larger for 2004-2005.
The major brake warpage problems started occuring in the 2000-2001 models, so I designed a bracket so you can use your 2000-2001 calipers and relocate them over the 2004 rotors.. This saves you the cost of replacing calipers for those of you that want to keep them. The setup also fits under the stock 17" wheels. (not the 16s)
You can see some pics and more info of it on my webpage..
http://www.mattblehm.com/brakes.html
(and no, I'm not tyring to ***** up this thread... you guys asked why he's putting 2k4 rotors on a 2k1, and I'm telling you.
), but think it might be for the 2000-2001's :-/
Originally Posted by MrGone
so do you make a bracket for the 3rd/4th gen to use 2004 rotors? Because I bought one (from another member
), but think it might be for the 2000-2001's :-/I want some 2k4 rotors but dont have the money for the any calipers!! lol
Maxspeed, the 99 and 00-01 are completely different brake systems. They use the same size pads, but the rotors and calipers are different. The calipers are about 4mm wider to accomodate the thicker rotors for 2000. Overall diameter is still the same though.
89-99 use the same front brakes, then it's 00-01, 02-03, and 04-05.
95-2003 all use the same REAR brakes.
Brake Pads are the same from 89 through at least 2001. on the front and rear.
You *could* grind out some of the 4th gen caliper to make it fit over the 2004 rotor with my relocation bracket, but I wouldn't recommend that. you'd have to remove about 4mm of metal there, and I don't want the liability of someone doing that and then something catastrphic happening. It's scary enough selling brake parts in general- you never know what bonehead is going to screw something up using your parts, wreck their car, then come back and sue me because they're stoopid!
shawn, you bought my 300ZX relocation bracket, not the stock 5th gen relo bracket, correct? The 300ZX relo bracket will fit any 3-4 gen, and I have another bracket to fit the 5 gen cars. If you bought a 5th gen 300ZX relo bracket used, then you'll need to drill out your spindles on the car for 14mm bolts. That's the only difference between the 3/4 and the 5 gen
I just wanted to make sure you actually made a bracket for the 3rd/4th gen, I never really hear about it anymore
and wanted to make sure lol. I bought it with my calipers and stuff, it wasn't really the high point of the package I bought (the calipers were
). Anywho, I was going back and forth between using the 12.6" or the cobra, but I figure it will be another $80 to use the cobras so I think I'll just stick with the 12.6"s. I dont really drive hard anymore :-/ The Irotors sound pretty good aswell, I'll have to see the price difference between them and Napa
Thanks again Matt
Just to elaborate on what Matt said, I ground my stock 96 calipers sufficiently to accomadate the thickness of the Cobra rotor. Specifically I had to grind on the torque member, which is the stock bracket which the caliper bolts to, which then bolts to the vehicle. It was quite a bit of work, took me probably 3 hours per side, using shop quality grinders. Just alot of grinding, testfitting, and grinding again, to make sure everything clears. I use these brakes quite a few times on the road course, so for me at least, they worked fine. I probably wouldn't do it again though because of the work/time involved, and the fact that the stock calipers are pretty small, with a single piston, and not enough pad area to cover the entire new, larger rotor. You would get better braking performance with a 300ZX (which still doesn't cover the entire new rotor, but covers more than the stock caliper) or alternate aftermarket caliper.
FYI, I've had Matt's BlehmCo BBK installed since last May. First try was with Axxis Metal Master pads + OEM Nissan 2004 Maxima rotors. They warped within 3 months, which is just like all my old OEM-sized rotor combinations I had.
Early October I installed 2k4 cross-drilled/slotted Irotors with Bendix Titanium IQ pads. It's been roughly 3 months with no slight indications of warpage at all. Granted, it's also winter, so maybe that could have an influence somehow, but I'm impressed so far. Only complaint is that the combo seems to be noisy (very squeaky)
Mar 12, 2020 12:06 AM
ik95
Sep 16, 2015 08:11 PM
