Can a bad camshaft position sensor cause my car not to start?!?!
It will. When I disconnect the wire feeding it, the engine wont start. But if the engine is running, if I disconnect the wire then, it will not stop it from running. I assume a bad camshaft pos sensor diagnosis signal sent to the ecu will disalloy it to start the engine.
Originally Posted by Monil
I got that same code. It actually was a bad starter giving me a bad camshaft position sensor code. Worked great after replacing starter.
I had it checked out at the dealer (I know, but it was free
). The starter wasn't not putting out enough voltage causing a misread in the position sensor. From everone else and if you tested the sensor it could be the sensor.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
doobadoo
Aug 15, 2015 06:43 PM
