99 SE Auto - rough 1 to 2 shift
Are there any known problems in this area ? The car only has 15K miles on it. I plan to take it to the dealer, but I'd like to know in advance if this is a known issue of any sort.
thanks,
Bob
thanks,
Bob
thanks,
Bob
thanks,
Bob
thanks,
Bob
thanks,
Bob
thanks,
Bob
thanks,
Bob
1) throttle position switch adjustment
2) transmission fluid line pressure
3) accumulator servo release
4) control valve assembly
5) ATF fluid temperature sensor
The FSM suggests these items be checked in the order specified.
Where do I go to read the computer codes ?
I suppose I should check them before I bring this to the dealer so I know what's what. But, I'm flying blind here since I don't have my factory manual yet.
Is there a web page that describes the code reading procedure for this model ?
thanks,
Bob
thanks,
Bob
Re: Where do I go to read the computer codes ?
thanks,
Bob
thanks,
Bob
the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Re: Thanks... one more ECU question...
Will the computer store codes without lighting the check engine light ...
... should I bother to check it even if the light is off ?
Re: transmission
Originally posted by timby01
I had the same prob but i have a 97 SE wind up being the transmission control and solenoid...Dealer even told me this is a common prob
How much did it cost to replace the transmission control and the solenoid?
Re: Re: transmission
Originally posted by HLDmax
I have this problem on my 97 GXE auto 79k miles. I tried changing to Synthetic ATF but that did not really help.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
