300zx wheels and rain
Old Feb 2, 2005 | 06:14 PM
realcarsRmanual's Avatar
I am considering getting 300zx wheels for my max, but i know that my dad hates to drive his 300 in the rain because it spins out very easily. I'm just wondering, do you loose any traction in the rain when you put the 300zx rims and tires on?
Old Feb 2, 2005 | 06:17 PM
Mizeree_X's Avatar
Getting back to his roots
If the tires are balding, then yeah, you probably will. Just because they are 300zx wheels and tires doesn't mean you will inherently LOSE any traction in wet conditions.
Old Feb 2, 2005 | 06:24 PM
95turbo gxe's Avatar
Maybe its a heavy modded tt 300z
Old Feb 2, 2005 | 07:05 PM
90maroon15.1's Avatar
well the 300z's are rear wheel drive.. and the max is front so ull get a lot better traction in the rain and snow as long as ur tires are good
Old Feb 2, 2005 | 07:58 PM
Cliff Clavin's Avatar
Way out West
Spinning out in the rain has nothing to do with your wheels. Your tires on the other hand...
Any car with good tires should be able to have little problem driving in the rain.
Old Feb 2, 2005 | 10:20 PM
jwmaxse's Avatar
It all has to do with the tires. BTW, you do know that you will need wheel spacers don't you?
Old Feb 3, 2005 | 09:43 AM
Bman's Avatar
Everyone beat me to it, but...
1) RWD + lots of horses
2) Tires
If the tires are worn down, older, or maybe a high performance type that isn't good in rain, then these just make matters worse. Just pick a tire with good rain performance (there are tons of good choices) and you should be fine.
Old Feb 3, 2005 | 11:09 AM
MrGone's Avatar
well wheels can effect wet performance alittle but, but not the 300zx wheels. Just interms of width and weight, but tires are the main thing
Old Feb 3, 2005 | 11:25 AM
Wiking's Avatar
Yes, wheels make it all. If rubber composition, thread texture stays same, the narrower the tires are, the better traction on snow & wet roads. Also narrow ones handle better on worn, groowed higway...
The higher the tire cross section, the more pleasant grand dad ride. Shops try always to sell F1 tires, cannot understand why. Most driving [to me, maybe to most] is commuting style which means need for comfort; low cross section gives horrible noise and jumpy ride - good only at track...
BkGreen97
Apr 2, 2016 05:47 AM
jsmith24
Feb 1, 2016 12:35 AM
Excalibur23
Oct 13, 2015 04:33 PM
BrandonCause
Sep 14, 2015 10:41 PM
16_SR
Sep 9, 2015 07:14 PM
