Alignment problem
Old Feb 5, 2005 | 07:47 AM
fadeaway's Avatar
Go Hokies!!
Alignment problem
I got my car aligned at some performance shop, just to make sure everything was done correctly. They fixed the toe, centered the steering wheel, and there was no need to adjust camber since it was just barely within factory spec with my drop.
The car was pullying crazy to the right before the alignment. About a day after the alignment, I noticed the car pulling right like crazy again. But I noticed after making a 90 degree left turn, it will go back to almost perfect. But then after making a right turn, it'll get worse again.
Anyone ever heard of a problem like this?
Old Feb 5, 2005 | 10:21 AM
nick's Avatar
something is binding in your steering , it could be number of things , but take a look at your strut bearings first, also take it back to alignment shop , be nice and explain your problem. Keep us updated
Nick.
Old Feb 5, 2005 | 10:39 AM
fadeaway's Avatar
Go Hokies!!
Nick.
Thanks, I'm sure it must be the upper strut bearings. I'm having some clunking noises when turning the wheel at low speeds (ie. parking). I'll go to a nissan dealership and buy 2 new ones soon, and get them put in somewhere. I'm thinking about getting s-tech's soon also so I'll put them in when I do that, if I do end up doing so.
Old Feb 5, 2005 | 12:08 PM
njmaxseltd's Avatar
The strut bearings have no effect on your alignment.
Incorrect camber makes your car pull. Items the effect camber are the strut and the lower control arm. Something is loose, check the lower strut mount bolts and check the lower control arm for worn bushings or a bad ball joint.
Also check the upper strut mount, that shouldn't cause a drastic pull, but will cause some noise over bumps and when you turn your steering wheel. Make sure the center nut that holds the sturt piston in place doesn't move when you turn your wheels. If it's loose or moves side to side, replace the upper strut mount.
matts95max
Apr 23, 2025 10:44 AM
NewMax03
Oct 7, 2015 08:27 AM
06maxima55
Sep 28, 2015 04:29 PM
ivorton23
Sep 26, 2015 09:47 AM
