Help, how do you pop out the hazard and defrost buttons from the housing?
Old Feb 4, 2005 | 08:47 PM
overseaz's Avatar
Where can i get replacement bulbs for climate control etc..
They have a beveled plastic clip on one side like youd usually push so it would come through the front but there is only one, not two.. what do i do??
Dave
Ps. does the Hazard have a light in it for at night, like the others do?
Old Feb 4, 2005 | 08:56 PM
Maxima_Joe's Avatar
4th Gen Parts King
the hazard does light up red.there is clips on both sides one is very thin though.Just push on both sides they will come
big_al's Avatar
OK, first you need to push the side without the clip through. Grab the thing and pull side ways toward the tab side and get the backside through. Then use a flat head to compress the tab while holding the backside through the slot.
2nd ? - yes a red condom LED light
Old Feb 4, 2005 | 09:27 PM
overseaz's Avatar
ever since i bought my car ive had like no lights on my auto climate control and hazard etc.. can you buy these at the dealer? not the whole unit just the light part? im going to convert most to LED's but i want to replace some with stocks.
Now im trying to figure out how to get that snorkel tube off the auto climate control so i can take it apart. Can you get it off without cutting it?
Old Feb 4, 2005 | 09:34 PM
ThurzNite's Avatar
my hazard led just went out too.
Jae
Old Feb 5, 2005 | 03:07 AM
MIXXMAX's Avatar
Yes, you can buy the bulbs themselves in the A/C unit. There are 4 bulbs in total. I had just bought 4 from the dealer, since two of mine went out. They are about $5.95 each. As far as the hazard light, you can replace it with a LED if you solder it right, with a resistor, and make it fit inside the switch so that it can assemble back correctly.
Old Feb 5, 2005 | 07:32 AM
G4nismo's Avatar
dude when i tried to do the hazard led switch, u guys know the white plastic piece that allows the button to stay in place when pushed or whtever? well i somehow messed that up and know the switch won't work right, i would have to hold down the button so i just got a new one.
Old Feb 5, 2005 | 12:16 PM
ThurzNite's Avatar
how much is the new button?
Jae
Old Feb 5, 2005 | 12:34 PM
AntLis97's Avatar
the dealership that i went to sells the whole button for around $20, but thats in NY it could be different in CA
Mahmuth
Aug 16, 2024 08:23 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
