Engine shakes or shuts off when coming to complete stop
Hello,
I have a 91 automatic SE and have problems with the engine shaking or shutting off when changing gear from park to drive or reverse or when coming to a stop.
The engine idles fine when in park or neutral, around 700 rpm. But when I put it into gear the rpm drops to about 400-500 or shuts off.
What could be the problem? I need to get a smog check by this weekend. Do you guys think this will be a problem when taking the test?
Also, I have been hearing that it might be a vacuum leak. How many vacuum hoses are on the max.
Originally Posted by max_pusher
...The engine idles fine when in park or neutral, around 700 rpm. But when I put it into gear the rpm drops to about 400-500 or shuts off.
2. 'thousands' possibilities
3. its a problem if emissions too high
4. see. 3.
5. abut thirty brittled hose ends.
To figure out the possibilities, click on this:
http://www.cardomain.com/memberpage/748507/14
Hondarydr
Dec 30, 2024 06:15 PM
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
