need non-constant 12v source
Hey guys i am putting in a power inverter in the max and i need a 12v source that will only work when the key is in the ignition but is powerful enough to power about 400 watts....any input would be appreciated.
thanks,
Bashar
thanks,
Bashar
That's kind of alot of power. I wouldn't use the ciq lighter.
Are you sure you just plug it into a power source? It seems like with that much power it would have to work like an amp with power coming straight off the battery (probably with some pretty thick wire) and a remote turn on lead to the switched source. If not then maybe do it with a relay.
Power Inverters have a turn on lead that is totally seperate from the 12V main source. The cig. lighter should be fine for the turn on lead, you'll need to run a large wire tap right from the battery to effectively run a 400W inverter.
or you can pull the on off switch and remote mount it. you just lengthen both wires and mount the switch where you want it. do that with the relay and you have the safety of it cutting off with the ignition or off while driving ie only on when you want it.
Originally Posted by Torgus
there is no way your going to draw 400w off a 12 guage wire your trying to tap from. just run a cable from your battery.
Originally Posted by happyricefob
nothing special. i just wanna let u guys know that i have not encounter any problem with this setup for 4 months. i use 16 gauge amp wire to support the 175watt power inverter. 12v is getting power from 30amp wiper fuse (stock is 20amp), and ground is secured on one of the 10mm bolt under the steering column.
the other black wire connected to the 10amp meter fuse is my radar detector, which is also hardwired through the a-pillar to the top left of the windshield (hidden behind factory window's tint).
anywayZ i just wanna let u guys know that this setup is safe. and it is not necessary to hardwire 175watt (or less) power inverter from the battery.
http://forums.maxima.org/showthread.php?t=331389
although many people said it's NOT safe to get power from the fuse panel, but i have this setup for almost 1 year and nothing has gone wrong. no fire nor bad quality video or whatsoever.
so if u want to do it the hard way, listen to other people. i'm just here to share my own custom wiring and personal experience...
AaronL
Nov 15, 2020 11:52 AM
Hdnseek
Sep 9, 2015 05:55 AM
