Help Asap
Old Feb 12, 2005 | 09:33 PM
96white's Avatar
Help Asap
ok guys i was driving around earlier tonight and all my lights would work when i turn then on. Now im going out to pick a friend up and i turn the switch on the first notch and i have no lights front or rear. I turn it all the way and my head lights come on and nothing in the rear ? Is going on. Please help. I dont want to get pulled over.
Old Feb 12, 2005 | 10:17 PM
96white's Avatar
well thanks for your help guys i just got pulled over. If anyone would still like to help me out I would appreciate it since i have a fix-it ticket now.
Old Feb 12, 2005 | 11:21 PM
athlon omega's Avatar
Didn't see your post till now, but I would say check the fuses.
Old Feb 13, 2005 | 05:21 AM
Gibby's Avatar
Calm down. Your post was only up for 45 min. Anyway, no **** you got pulled over. You were driving without lights. Fix it ticket shouldn't be so bad, since you'd have to fix it anyway.
BTW, I agree to check the fuses first. This is cheap, easy and fast. If you continue to blow fuses, or if that doesn't work, use a multi-meter to check the continuity of the circuits for any shorts.
Good luck, and relax.
Old Feb 13, 2005 | 05:31 AM
maxima_kenny96's Avatar
ur fuses may be loose, I know that mine were so I got those fixed. I you have aftermarket lights like I do, I would check the connection between the bulb and the little wires that go in it, because that was my problem i just had to put it all in contact with the set up and then it started shining again...check ur connections.
Old Feb 13, 2005 | 09:00 AM
96white's Avatar
SORRY GUYS, I really should not have not have put up in my post last night, I was just more upset at myself because of what happened.
I want to check the fuses first but i dont know where to look because the inside fuse box doesnt have any labeling, and the ones under the hood, I dont know which one would cause all of them to fail?
Is there any place that had a diagram of what all the fuses do?
Once again, sorry guys, any more help or information would be great.
Thanks.
Old Feb 13, 2005 | 09:04 AM
Prophecy1's Avatar
Back of the fuse door it says.
Proph
Old Feb 13, 2005 | 09:35 AM
96white's Avatar
if you talking about inside the car, mine has nothing on the back of it ...
Old Feb 13, 2005 | 10:42 AM
96white's Avatar
The only thing that i can think might have caused this is i put red clears in the back friday night. Everything worked fine up until last night. I checked the wiring and harnesses and they are all in tight. As for fuses, I pushed all of them in incase one came lose.. still nothing.. Anyone else have an idea? I have to go back to school this afternoon, and I dont really want to go to the stealership.
Old Feb 13, 2005 | 11:01 AM
adithius's Avatar
Hey I dont have a diagram on me either, but if you take a needle nose plyer or a fuse tool, you can look at each one and see if the conections are okay. If you see the metal that is in the middle broken, that is the bad fuse.
Old Feb 13, 2005 | 11:26 AM
96white's Avatar
I just decided to finally start pulling out EVERY fuse until i found one that was blown, replaced and now everything works perfect.
FYI, if all your exterior lights dont work on the first postion, check #5 in the fuse panel by your left knee, its a 7.5 amp fuse.
Old Feb 13, 2005 | 02:33 PM
Gibby's Avatar
Glad to see things worked out for you. BTW, it wasn't the WTF I was commenting on, it was the middle finger icon. But no big deal.
Good day.
maxfever1987
Nov 19, 2016 08:01 PM
NewMax03
Oct 29, 2015 07:44 PM
MaximaRaj
27
Oct 2, 2015 07:31 AM
zzznightmarezz
Sep 21, 2015 06:32 PM
chernandez1278
Sep 16, 2015 01:18 PM
