My OBD II is not working
Old Feb 14, 2005 | 09:17 AM
98TitaniumSE's Avatar
I just bought an Actron OBD II Pocketscan, and when i turned the car on and plugged it in, I got nothing. I doubled checked on my brothers 04 Altima to see if it was the scanner, but it worked on his. So I removed the panels around the area, and looked around to see if the wiring was fine, everything was fine. The only thing I could see was a little yellow clip hanging there with 2 wires coming out of it, one being yellow. Is there anything else I can do to get it working?
Old Feb 14, 2005 | 10:36 AM
gtr_rider's Avatar
192.168.1.1
Are you sure its fully connected into the slot?
Old Feb 14, 2005 | 10:39 AM
s0ber's Avatar
Are you sure its the right slot O_O
Old Feb 14, 2005 | 11:25 AM
MDeezy's Avatar
that would really suck if something is wrong withthe ODB II port. . .
Old Feb 14, 2005 | 02:27 PM
OBD II Pics
I plugged it into the socket on the left side of the dash, here are some pics of the loose clip and the socket. The clip might be part of my viper 791xv, but I'm not sure. I'm not 100% sure, but the clip joins with the OBD II harness and both go into the main engine harness.
Old Feb 14, 2005 | 03:37 PM
A32Matt's Avatar
i'm not sure if it is the same with the '98, but on my car the OBD port is on the right side of the center console. Might wanna take a looksee there.
Old Feb 14, 2005 | 09:52 PM
I didn't see anything on the right of the center console.... does that clip have to connect somewhere up in the dash in order for the information to be sent to the code scanner?
Old Feb 14, 2005 | 10:02 PM
DAVE Sz's Avatar
Hooooooonda.....
that's where all 95s have the obd2 connector.
Old Feb 15, 2005 | 10:59 AM
Pearl99GXE's Avatar
Your are connecting it to the correct place. That is where I plug my code reader into.
Old Feb 15, 2005 | 12:24 PM
tcf_dk's Avatar
That yellow wire that you see could be the one that connects to the plug underneath your steering wheel cover that beeps when your light is on when you exit your car.I never noticed a beep till I found a wire set like the one you're talking about and plugged it in.Then the car beeps if the lights are on with the door open.I'm not 100% but I'll check.
MAXSE5SPD
Sep 17, 2022 04:00 AM
mvm062
Nov 30, 2020 09:00 AM
kmitchel
Oct 30, 2015 10:12 AM
iflexsteel
Sep 2, 2015 08:04 AM
Hailstatejig
Sep 2, 2015 06:52 AM
