My OBD II is not working
Old 02-14-2005 | 10:17 AM
98TitaniumSE's Avatar
I just bought an Actron OBD II Pocketscan, and when i turned the car on and plugged it in, I got nothing. I doubled checked on my brothers 04 Altima to see if it was the scanner, but it worked on his. So I removed the panels around the area, and looked around to see if the wiring was fine, everything was fine. The only thing I could see was a little yellow clip hanging there with 2 wires coming out of it, one being yellow. Is there anything else I can do to get it working?
Old 02-14-2005 | 11:36 AM
gtr_rider's Avatar
192.168.1.1
Are you sure its fully connected into the slot?
Old 02-14-2005 | 11:39 AM
s0ber's Avatar
Are you sure its the right slot O_O
Old 02-14-2005 | 12:25 PM
MDeezy's Avatar
that would really suck if something is wrong withthe ODB II port. . .
Old 02-14-2005 | 03:27 PM
OBD II Pics
I plugged it into the socket on the left side of the dash, here are some pics of the loose clip and the socket. The clip might be part of my viper 791xv, but I'm not sure. I'm not 100% sure, but the clip joins with the OBD II harness and both go into the main engine harness.
Old 02-14-2005 | 04:37 PM
A32Matt's Avatar
i'm not sure if it is the same with the '98, but on my car the OBD port is on the right side of the center console. Might wanna take a looksee there.
Old 02-14-2005 | 10:52 PM
I didn't see anything on the right of the center console.... does that clip have to connect somewhere up in the dash in order for the information to be sent to the code scanner?
Old 02-14-2005 | 11:02 PM
DAVE Sz's Avatar
Hooooooonda.....
that's where all 95s have the obd2 connector.
Old 02-15-2005 | 11:59 AM
Pearl99GXE's Avatar
Your are connecting it to the correct place. That is where I plug my code reader into.
Old 02-15-2005 | 01:24 PM
tcf_dk's Avatar
That yellow wire that you see could be the one that connects to the plug underneath your steering wheel cover that beeps when your light is on when you exit your car.I never noticed a beep till I found a wire set like the one you're talking about and plugged it in.Then the car beeps if the lights are on with the door open.I'm not 100% but I'll check.
MAXSE5SPD
09-17-2022 05:00 AM
mvm062
11-30-2020 10:00 AM
kmitchel
10-30-2015 11:12 AM
iflexsteel
09-02-2015 09:04 AM
Hailstatejig
09-02-2015 07:52 AM
Quick Reply: My OBD II is not working
