newb troubles
Old Feb 15, 2005 | 08:45 PM
Akumachan's Avatar
I never narc'd on nobody.
newb troubles with wiring
ok, so i went to install a new shift **** today, and it wanted to be plugged into the gauge cluster power source, so it would light up when my headlights are on. no biggie, but i figured, any ol lpower source would work, and i dont exactly know how id go about routing the wiring all the way to the gauge cluster, so i wired it into the defroster light, and... **** no worky, so i figured maybe that just dont have enough juice to power the ONE led in that thing, so i spliced into the cig lighter, and still no dice. so i guess what i wanna know is, is there really a way this thing could tell the difference (wattage/amperage) between either of the aforementioned power sources and the gauge cluster, or is it just not working. and also, if it is just picky, where would i find a good + power source from the gauge cluster that wouldnt require to totally mutilate my entire dash? thatnks for any and all help.
Old Feb 15, 2005 | 09:36 PM
Akumachan's Avatar
well, to add to this, and also as a bit of a bump, what size are the bulbs that are in the automatic climate control?
Old Feb 15, 2005 | 11:47 PM
DRIFFT MAX
look for a constant power source that works, ur cig liter should have worked unless it blew ur fuse......hmmm. not sure , i wired all my interior neons to the cd player and ran that to a switch. good luck bro, love the sig
Old Feb 16, 2005 | 12:02 AM
Akumachan's Avatar
yeah, thanks, im thinking maybe i just chose a crappy grounding point. at first i used one of the screws that holds all the sterio and whatnot into the dash, then when i changed to cig lighter, i used the black wire on the cig lighter, and by the way, the fuse is fine cuz the cig lighter still works. anyone else? or is this thing just busted... cuz that would **** me off, it was new in box and all.
Old Feb 16, 2005 | 09:04 AM
Akumachan's Avatar
anyone? i want to get this ting working.
Old Feb 16, 2005 | 09:13 AM
erty67's Avatar
Decal Specialist
Ground --> you can use the front bolt for the pass seat, if nothing else.
power source --> Fuse box The cig lighter should have worked though
Old Feb 16, 2005 | 09:14 AM
erty67's Avatar
Decal Specialist
hey, try testing the light by connecting it straight to the battery. make sure it works
Old Feb 16, 2005 | 09:28 AM
Akumachan's Avatar
alright, ill try those out after school, thanks for the help.
14GmMax
59
Aug 4, 2019 11:26 AM
zmcneely13
Sep 26, 2015 02:26 PM
msellas
Sep 23, 2015 09:16 PM
Socalstillen
Sep 20, 2015 11:46 PM
