humming sound from wheels... bearings?!
Old Feb 15, 2005 | 08:52 PM
naslime's Avatar
hi fellows
i have a humming/wuu wuu wuu sound coming from the front wheels. has anyone had this problem? could it be the bearings? what could happen if they don't get changed soon enough? can the wheels lock up on me?
any ideas? gotta take a trip to NY on thursday, so i wanna have the car in good shape for the trip.
thanks
Old Feb 15, 2005 | 08:54 PM
Wisky97SE's Avatar
You know its a wheel bearing if you hear a consistant humming, more noticable at freeway speeds. You can determine which side it is by listening to when the noise gets loud as you switch lanes, or take a sweeping turn. Although you can usually drive on a broken wheel bearing for a little bit, I would suggest you get it replaced before your long trip.
Old Feb 15, 2005 | 09:05 PM
alpicone's Avatar
Or it could just be noisy tires.
Old Feb 15, 2005 | 09:10 PM
Kevin's Avatar
i'm gonna guess its the bearings. when you're rolling put it in nuetral nad see if the noise continues. if it does I woudl guess its the bearing
Old Feb 15, 2005 | 10:45 PM
Turk's Avatar
My car had the same problem. Water in the tire was mine. My dads problem was that the CV shaft nut was loose. Check the nut first.
Old Feb 15, 2005 | 11:12 PM
kbmaxima's Avatar
uneven wear on the tires too maybe?
Old Feb 15, 2005 | 11:23 PM
jcy98maxse's Avatar
Turbo is too much fun!
Mine are from tires, back tire hum at crusing speed due to lack of rotation, now I have them in the front and they continue to hum. Rotate your tires first and see if the problem still exist.
Old Feb 15, 2005 | 11:47 PM
lshi0's Avatar
i have same problem, any other symptoms beside noise?
Old Feb 16, 2005 | 12:00 AM
blbrizzi's Avatar
Originally Posted by naslime
hi fellows
thanks
Is this only happening when you are braking? My experience shortly after my brakes were changed is that they make a humming noise when coming to a stop, this can be because of the quality of the brake pad used. If it's your bearings, it would probably be more of a grinding noise, I have had this happen twice with two different vehicles, one of them being my Infiniti I-30t. Also, yes if it is this problem, you will do more damage by continuing to drive it. Good luck.
Brent
Old Feb 16, 2005 | 12:28 AM
lshi0's Avatar
u mean without moving the car?
Old Feb 16, 2005 | 04:39 AM
naslime's Avatar
i know the noise is not coming from the brake pads. i've had the car for about 2 months and did not notice the noise before, maybe i just had the music too loud. it could very well just be noisy tires but i thought continentals were a better quality tire. do you still get tire noise from good quality tires?
Tman - how do you get water in the tire? driving in the snow or something? if that's the case, i did drive in the snow in my last trip to NY.
Wisky - the noise does not really increase or get worse when i turn or change lanes. the humming is really the only symptom.
thanks for all the replies!
Old Feb 16, 2005 | 05:42 AM
naslime's Avatar
also...
what tire pressure should i use? the 29 psi recommended on the plate under the arm rest?.. or do you guys use something else?
Old Feb 16, 2005 | 08:32 AM
kingrukus's Avatar
no more maxima...
Any idea as to what would happen if I drove on a screwy wheel bearing for nearly 2 years or 40,000 miles?
Old Feb 16, 2005 | 08:42 AM
alpicone's Avatar
Filling up air from a compressor that isnt drained regularly. Condensation ends up in the compressor and if it isnt drained periodically it ends up in your tires.
Old Feb 16, 2005 | 08:54 AM
Kevin's Avatar
no while moving, somehere in a parking lot or something.
Old Feb 16, 2005 | 09:29 AM
96white's Avatar
does anyone have a price to fix the wheel bearings or a write up on how to do it?
thanks
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
Andy29
Sep 29, 2015 05:32 AM
