Need to fix grounding noise on FSTB - still don't know what AC pipe everyone mentions
Old May 1, 2001 | 05:02 AM
duplex's Avatar
My front strub bar makes some slight grinding noise when starting out slowly, or when gears shift. Eveyrone tells me to bend down the AC hose on the passanger side. The only thing on the passanger side that I can see potentially hitting the bar, woudl be the metal/aluminum bar. I dont know if i can bend that one down. Also in the middle i see small rubber houses but I dont think thsoe are it. Anywyas, if you can take a pic, and show me where that house is on a 96 or similar, that would be awesome thanks!
Old May 1, 2001 | 05:23 AM
matty's Avatar
bro on the passenger side that alluminum bar is the a/c line running up the side of the engine..i tried pushing it down so it doenst rub but its too strong so all i did was bend it toward the engine...another thing you can do it take the bracket off that holds the a/c line and drill a little hole in toward the top to move that hole thing down a little bit..its only like 1/4in off...i bent it back a little...if it pops back then ill drill a hole to move it all down..peace
Matt93SE
May 24, 2019 02:58 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
Balkins
Aug 12, 2015 06:39 AM
