wot wiring??
Old Feb 17, 2005 | 09:39 PM
akadiablo's Avatar
wot wiring??
I have been told that I need to use a multimeter, and see what wire is getting power when throttle is wide open off of the tps.. Is this correct?? or is there a wiring diagram somewhere that would make it easier???
Old Mar 2, 2005 | 02:31 PM
brad kay
guess and check method
Old Mar 2, 2005 | 04:52 PM
subs1000w's Avatar
i was going to do that on my 3rd gen but the factory WOT switch reads 12V at WOT but still reads 9v at closed so i didnt use that because i think 9v might still trigger the relay
i ended up installing a pushbotton switch under the gas pedal to hide the setup alittle more
Old Mar 2, 2005 | 07:33 PM
TAPOUT's Avatar
You will lose
You need this: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Mar 6, 2005 | 10:23 PM
akadiablo's Avatar
ohh man you guys are impossible.. The white wire coming from the tps, the connector with 3 wires, you need to tap into the white wire.. i did, and it works fine, but if you all wanna rig up the universal wot switch, go for it... Gees....
trsandrew
Apr 8, 2016 06:45 PM
doctorpullit
Mar 29, 2016 11:08 AM
trsandrew
Oct 25, 2015 02:47 PM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
