Detailing Discuss how to make your car sparkly clean for car shows, local meets, or any other reason. What products do others use and how do we get them? Get your questions answered in here.
Zaino'ed 4th gen
Old Feb 26, 2005 | 12:40 PM
THT's Avatar
THT
Throbbing member
Zaino'ed 4th gen
I didn't have to work today and it was nice enough that I decided to wash and Zaino my car. First, I washed the car with Dawn soap so it would strip any remnants of pre-winter wax. Then, I washed her again with Z7 and dried with a microfiber towel. The Zaino application was easy with three coats of Z5 and a coat of Z2. When I removed each layer of Zaino, I spritzed her with Z6. All in all, it took me four hours but she's gorgeous! The wheels will be coming off in a month or so and I'll be putting my SSRs back on.
~THT
Old Feb 26, 2005 | 12:43 PM
CaLSoNiC
Ooooooo.... I like
Old Feb 26, 2005 | 12:56 PM
MaximaTodd's Avatar
G
looks good. i used to do the same zaino treatment as you are doing until i discovered meguairs nxt wax. one coat of that stuff looks equally as good as meguairs and takes a hell of lot less time. not to mention the meguairs is a lot cheaper. but nontheless, great job.
Old Feb 26, 2005 | 08:42 PM
Bluesbrekr's Avatar
Doctorate in Detailing
Are those scratches on the tops of the wheel wells on the front left and right rear or just reflections?
Shine looks pretty good!
Old Feb 26, 2005 | 08:44 PM
THT's Avatar
THT
Throbbing member
Reflections
~THT
Old Feb 27, 2005 | 10:19 AM
Ammi's Avatar
350 Detroit Muscle
looking good
Old Feb 27, 2005 | 01:22 PM
E55AMG2's Avatar
Wat
Looks great
Old Feb 28, 2005 | 10:19 AM
Phil75070's Avatar
I have used NXT and just this weekend tried Zaino. I washed with Dawn, did the California Water Blade follwoed by a quick dry with a WWMF. Then I only did one coat of Z2 followed by a quick spritz and wipe down with Z6 and Zaino beats NXT hands down in my opinion, at least on my '05 Smoke.
Old Feb 28, 2005 | 10:50 AM
E55AMG2's Avatar
Wat
Zaino products are overrated IMO, Klasse does a better job with considerably less effort. Pretty much, they are the bottom of the upper end product line simply due to the effort vs outcome.
Old Feb 28, 2005 | 01:33 PM
THT's Avatar
THT
Throbbing member
I have yet to use Klasse. When I run out of Zaino, I'll probably give it a go. Zaino isn't cheap but it sure beats any wax/polish I've used to date IMO. That and Zaino requires zero effort to put on and take off whereas wax can be a PITA if you put too much on.
~THT
Old Feb 28, 2005 | 02:34 PM
E55AMG2's Avatar
Wat
~THT
Zaino takes too much time to cure, and even with numerous coats still doesnt look as good as say klasse with a topcoat of s-100 (which takes 30 min for the klasse to cure versus an hour in between each zaino step, then about 15 min to apply and remove the s-100). If you think zaino looks better than any wax you've used, you might be using the wrong waxes/polishes.
If you really want the car to look perfect: einszett paint polish, then metallic polishwax, Klasse SG, then a topcoat of s-100 carnuba wax. The combination of the sealant under the carnuba topcoat not only looks amazingly deep, but will last a while too.
Old Feb 28, 2005 | 04:15 PM
PrinzII's Avatar
OG and counting...
E55, my esteemed colleague, that may be true. But if ZFX is mixed in there, the cure time is the same as Klasse.
Old Feb 28, 2005 | 09:00 PM
E55AMG2's Avatar
Wat
Still more work than its worth
Old Mar 1, 2005 | 02:16 PM
BobbyG123's Avatar
Zaino takes too much time? What's the world coming to? I can TOTALLY detail my car with Zaino in 4 hours and it lasts up to 4 months. I'm sure there are several products on the market that do a great job, but once your comfort/experience level is up with Zaino, it's a piece of cake. The ZFX has made all the difference IMO.
Either way, it's not worth fighting about. There are several quality products on the market now, and our cars will look better because of them.
Old Mar 1, 2005 | 03:42 PM
E55AMG2's Avatar
Wat
Phase 2 does as much or better than zaino and takes 45 minutes in total...
MAXSE5SPD
Sep 17, 2022 04:00 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
imported_Nismo_max
Sep 21, 2015 07:24 PM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
