DESPERATE help needed, car won't start
ok, here are the symptoms:
it's like my battery is not giving full power for some reason. I can turn the lights on, but the second I try to start the car, everything shuts off. and now it's in a phase where after i lock the car, the locks make this ticking sound. I've had this problem before, and I thought it was attributed to my grounding kti and a conenction being loose, but I removed the whole grounding kit, and I tightened both battery terminals as tight as god would let me. ANY suggestions would be of help. Thanks.
the only jumper cables we own are in a parking lot at the airport. I could gain access to em later today, I'm thinking that's the easiest possibility to fix. Let's hope the battery or alternator doesn't need to be totally replaced.
how is the fluid level in the battery? If its low, add distilled water and jump it. You should use some salt water to clean off that positive terminal just to make sure it isn't corrosion.
Also, does your starter start to turn at all? Or does everything go dead and your car is quiet? If everything goes dead, could be the clutch interupt relay (yes I know you are automatic, but they have them too). Try starting your car in neutral. If it still does nothing, could be one of the three (at least my 95 has 3) clutch interupt relays. They are designed to keep your car from starting while in gear.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
MAXSE5SPD
Aug 23, 2015 12:06 PM
TonyJr
Aug 20, 2015 12:14 AM
