My brakelights won't light up....Help!
Do your parking lights come on? Theyre on the same circuit. I had this happen where I kept blowing fuses. Turned out to be a wire rubbing against the metal on the trunk lid and causing a short.
It made me absolutely furious for about 5 days before I found it. I fixed it that day in january when it was 8 degrees in NYC.
One bad bulb can make this happen too. Check your fuse first. Then the bulbs. Both tail light bulbs and the parking lights. Sometimes if you just remove and reinstall the bulb they will start working.
If that doesnt work just repost and we'll move on from there.
Any insight fellas??
i had the same issue, it's the Tail.L 7.5 fuse,...it's in the bottom-left corner. you should see 2 7.5's ....replace the upper one kept blowin on me, then i replaced it with a 10 amp fuse, lights stayed on, but i'd get a shock everytime i got out my car and touched the door.
boomerbrian
Oct 31, 2018 10:25 AM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
JoshG
Sep 5, 2015 10:10 PM
Thanks everyone for your input.
