Replaced knock sensor, something not right
I just replaced the knock sensor today and my car runs really rough now. To change the senor i took out the upper intake manafold and all the other stuff that the haynes manual says to do excpect take out the lower intake manafold. I was able to loosin it enough to raise it about a half inch which gave me enough room to access the knock sensor. Once i got everything back together i took it for a spin. It idles rough and drives rough now. During acceleration it feels like the car cuts out and not smooth. Any help would be great.
Tom
Tom
1 maybe you messed the gasket (just a guess)
2 you should've spent $15 dollards on a rachet extension and 12mm swivel socket. and done the change in 10 minutes.
3 check for codes
4 maybe a coil is not working
5 moist in the cilinders?
6 do a seam foam cleaning
7 clean the TB
these are things I would think about doing it
P.S. funnny thing is, just today it took me 10 minutes to take off the Knock sensor from my crashed maxima.
3 check for codes
7 clean the TB
So you raised the lower manifold? You probably have a bunch of air leaks and the engine is getting alot of unmetered air. You should NOT have just lifed the lower manifold and not replaced those gaskets. Those are important. That's why they are expensive. I think the lower has some coolant jackets that the gasket has to seal off from the intake manifold air.
you have to replace the gaskets dude. antything that has gaskets especaily having to do with intake you have to replace the gaskets. think about it if you have used it once its already been smashed down, if you dont replace it there is gunna be a leak
Any gasket you take off is one you need to replace.
Originally Posted by 97BLKMAXSE
This sucks. I just spent 6 hours working on it today and now i have to take in all apart again. What gaskets do i need?
I didnt take off the lower intake manifold because i couldnt get the ingecters to come out. any suggestions?
Ii took out the upper intake manafold and all the other stuff that the haynes manual says to do excpect take out the lower intake manafold. I was able to loosin it enough to raise it about a half inch which gave me enough room to access the knock sensor.Tom
Im going to replace the gaskets tomorrow but i cant get the injectors to come out. they need to come out in order to take the lower manifold out. does anybody have any suggestions on how to get the injectors to come out. also is there anything else i should know before tackling this again.
mrc00l88
Jan 25, 2024 01:14 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Aug 20, 2015 02:17 AM
