Camshaft Position Sensor
Old Mar 17, 2005 | 03:32 PM
Skiptronic's Avatar
I pulled another code, 0101. ECU says somethings wrong with the Camshaft Position Sensor. I've checked all the stickies but can't find anything about it. Can I get a point in the right direction as to getting this fixed?
Old Mar 17, 2005 | 03:37 PM
mattC's Avatar
0101
My book says DTC 0101 is caused by the Camshaft Position Sensor (Phase). This sensor is located on the engine front cover facing the camshaft sprocket. It detects the cylinder number signal. The Engine Control Module uses this signal to control spark plug firing order and also to sequence the fuel injectors correctly. If the CPS is bad the ECM will fire the plugs at the wrong time, or not fire them at all. This would account for a no-fire symptom.
that was searched btw.
Old Mar 17, 2005 | 03:44 PM
Kevlo911's Avatar
Kevlo for President
http://forums.maxima.org/showthread.php?t=235667
Sure did a good job looking at the Stickies
Old Mar 17, 2005 | 03:49 PM
Ant96GLE's Avatar
You can actually clean it, it doenst always have to be replaced.
Old Mar 17, 2005 | 04:49 PM
Skiptronic's Avatar
I saw that in the stickies. It doesn't say what I can do about it. Just what it is. I'm looking for a way to get it replaced or fixed, as I asked in my previous post kevlo911.
Thanks for your help Ant96GLE. Do you where its located so I can clean it?
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
