Voice Warning System
After searching for hours about the Nissan voice warning system, I came up with virtually nothing. So I decided to sign up here and see if you helpful folk could give me a hand with some stuff.
I remember hearing the Nissan voice a few years back and ever since I wanted to get ahold of the voice module to see how it works and install it into a car. I've already worked with Chrysler's version which is a computer synthesized version and have wiring diagrams on how to install the unit.
I'd like to put a voice into my Shadow but Chrysler's is male. The Nissan one is female. As the car's name is "Hailie" she needs the female voice box. Plus, it seems the Nissan one is simple as it doesn't monitor as much as the ChryCo one does. So I'm looking for wiring diagrams, pictures, sound clips, and the modules themselves. From what I've read the Nissan one uses a little record? Are all of them like that or just early ones?
Anyway, thanks for all your help and I really hope SOMEONE has audio recordings of the darn thing...
it dosent have a lil record its a computer chip the big as one in the middle, and to take out the wireing youll have to take that whole car apart for the different responses like, "fuel is low, right door is open, left door is open, keys in the ignition, parking brake is on". good luck.
My guess is that the sensors in the Nissan just send a ground to the voice box to trigger it's responses. That's how the Chrysler EVA works. My Shadow has the needed sensors/switches that should trigger all of what it needs to say so I have to splice the Nissan voice box into the Chrysler wiring. Shouldn't be too bad once I get the wiring for the box.
Went to the Junkyard today....... found ONE old Maxima (think it was a 87-88, had auto seatbelts)...
Forcibly ripped out the center console and found a small goldish color box. Cut the wires to it and took it happily after they charged me $10 instead of the $5 like they said they would (they wanted $15 but I fought that after two hours of slippery sloppy MUD and the imports are in the way back). I had a bad feeling when I got up to the counter as I didn't remember seeing the voice repeat/off switch... but it was in the right spot... also had the shock switch thing too but behind it was a plastic plate where the swich probably was suppost to be...
Went to the Nissan dealer... the box is a cruise control module... $10 wasted...
Anyone need a cruise module for a V6 Manual Transmission Maxima?
I finally acquired TWO voice boxes from the 84-87 Maximas along with the repeat/off switches for them. Could someone email me the wiring diagram for the boxes? I'd like to start the testing and install of these into my Shadow.
Voice System
This is somewhat off the topic of installing the Voice system into a newer car.
I have several manuals to the maxi, yet i cannot find anything about the voice warning system. I have an 87' born in 86' with the voice system, however the only thing she says is "Fuel Level is Low" and thats it, nothing else. Do y'all think the control box is fried or the wires from all the other sensors, or a ground issue?
-rich
-rich
Not sure if anyone is still looking for a write up on *****in Betty, but someone over on tt.net made one.
enjoy
http://www.twinturbo.net/net/viewmsg...msg_id=1015155
And if you still have the spare box... I'm interested
enjoy
i have a module, its part number 25925 32E60 if any one wants it for $20.
and if the speedo isnt working in the car all the time it sounds like the gear at the end of the cable has teeth missing off of it and stops if it gets to where theyre gone
litch
123
Jan 4, 2024 07:01 PM
