injen vs berk
injen vs berk
Not sure if anyone cares, but I thought I would post this anyway. I had an Injen CAI with Heat Sheild on my Max for about 2 weeks, and it was OK. I notices some low end tq loss, but it moved after 3500RPM. Nice gurgling sound as it sucked in the air. Then I got a Berk WAI with Apexi filter. Better performance all through the power band, but does not gurgle as cool at higher RPMs. It does have a nice sucking sound even at low RPMs though. I think it works better with Berk because the distance from intake manifold to the air filter is a lot shorter. Overall, I think the WAI is better, and more responsive. It may not generate as much tq and hp in the end, but the responsiveness over the Injen CAI and stock air box is definetely better. Peace...
Originally Posted by Maxima-Ness
I still think its funny how Injen calls it a CAI even though its still in the bay.
Check the dyno forum, I did a few tests with various forms of the GAB and a midpipe.
Not ebcause I "felt" an improvment, but actually proved it
How do I find info on this setup? Is it sold as an assembly or components?
How much? Any pictures??
Any links to seller is welcome !!
got it.
http://www.berktechnology.com
Thanks !!
Originally Posted by NmexMAX
use a coat hangar, probably gives better results.
Hey.. I do care!!!!
Originally Posted by GBAUER
...until if falls off letting dirt clog up your maf, dirty your intake, clog your injectors, and throws a rod!
"...until if falls off letting dirt clog up your maf, dirty your intake, clog your injectors, and throws a rod!"
I have had a coathangar GAB for 20k miles now with no problems with it falling off. I dont think it can actually fall of unless the coathangar gets bent to hell somehow. Also I use K&N filter grease. The grease makes sure it seals well when installed and actually is sticky enough to hold the filter in properly without the coathangar bracket.
...random hysteria and misconception!
How would it clog your injectors or throw a rod anyway?
Originally Posted by PTP
Is there any increase with gas mileage (or loss?) with the Berk?
Got mine for $99 shipped when Berk was having a clearance sale...
Just PM Cobymoby (his real name is Bryan) and find out the current prices and if they're having any sales going on....
Okay, don't get me wrong, I wasn't trying to be a jerk, since you've done more than most of us by trying 3 different set-ups and ya get props for that. Thing is, we've already heard a lot of similar opinions on this in the past, and in general, personal "feel" and the butt dyno haven't proven to be that accurate. The best way to do a comparison would be to dyno the 3 set-ups and let us know what the numbers and plots say (I know, ya already knew this). There's already a comparison that Studman did in the FAQs for the Place Racing CAI, GAB, and a short RAM of some sort (shortened Place Racing), but no one has done one recently with set-ups like the Berk/Frankencar, or Injen/eBay intakes... I think the results will be similar to what Studman found, but we need one to finally end the endless debates...since there're always heated discussions about the gains of those.
Glad ya like the Berk though...
Check the dyno section now, I updated some plots. I saved my money with the berk/injen and used it on a dyno more uselful IMO
... ya must have spent a ton of money on those dynos too (unless ya got hooked up) anyways... thanks for the update... I'm thinkin I may check out the GAB set-up sometime...
Btw... do ya have pics of the GAB w/ midpipe set-up? I'm curious to see how ya fit that all in there... I know ya had to cut the mid-pipe a little...
as far as I know...a correctly made GAB will not fall off...take my experience as a good example....coilovers+low profile tires+stiff motor mounts....still no signs of GAB falling offl
Originally Posted by 92ve5spd
where do u get coathangar intakes? did a search or google and nothing. do they have a website?
Where do you find a coat hanger? Well, I'm not sure if they have a website. Check your closet, maybe?
Originally Posted by spiromax
Are you serious? You don't get the coat hanger intake from anywhere. You make it... with a coat hanger...
Originally Posted by super6
seroiusly can someone tell me what the hell is a coathanger intake? now im just so darn curious.
Yah, its rediculous that Berk charges $180 for 10 inch peice of aluminum. But we pay for it, so there is a market.
isn't the $180 for all the components and an Apexi filter? I think the midpipe alone is more like $60 (not that its cheap)....
Yeah, its the whole setup with Apexi filter. But that part cant be more than $50 or 60. So $110 for the aluminium tube? They are making a killing on profit. But I like it, so cant b!tch.
