Fried harness
Fried harness
I think I may have fried the connector of my wire harness for my driver side headlamp. I was messing around with the fuses to see if I could disable he DRLs and when I tried to check the driver side headlamp was not working. I checked the bulb and even tried a different one and it didn't work either. I checked all the fuses and they were all fine. So finally checked the plug and I noticed that part of it had melted and it definitely didn't look like the passenger side one.
Does anyone know how cheap this part is or how easy it would be to repair?
I'll try to post pics.
Originally Posted by ornery1
its from improper wattage lights you probably have in. the plug comes with about a foot of wire. i put em in my car after both did exactly that and no problems since, also changed bulbs to propper wattage.
double check i think stock is 55/65 that usually only happens when there is a higher watage bulb. replace it and after 10 min with the headlights on feel the connector. it should not be hot. mine burned so bad it filled the headlight with smoke and i hade to remove and clean the inside lense.
the plastic connecter melts because of a high current draw. have u had this car from new? maybe someone else had different bulbs in. and now it is just acting up again....
Both of my plugs look like yours, but even worse ! I ran Piaa SuperWhites stock wattage for 2 years, and for the last 2 years I been on Silviania SilverStars. I have to open the hood every other time at nite when I fire up my car and jiggle the connectors to get the lights to come on !! Sucks, but I have 02-03 headlights in my room just need to get some bulbs for the high beam, parking and turn singal lights. I bought the special HID harness from Nissan that gives you all the plugs for the 02 lights to connect them to my 01. This week I should have the 02 lights on my car
magiconthetire
Oct 26, 2015 09:03 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
