advance timing bad?
Old Mar 27, 2005 | 06:14 PM
theMax's Avatar
advance timing bad?
Looks like some are getting some good gains by advancing the timing. Just to confirm this is bad for nitrous correct?
Could you do the timing advance if you had colder plugs or is this not the same issue?
Old Mar 28, 2005 | 09:08 AM
subs1000w's Avatar
generally its not a good idea but i have mine advanced to 20 degrees and havnt had any problems
Old Mar 28, 2005 | 09:34 AM
theMax's Avatar
Why exactly is it bad? I assume detanation so colder plugs may help?
What heat range plugs are you running?
Old Mar 28, 2005 | 03:28 PM
subs1000w's Avatar
bkr6es 1 step colder
it gives detenation more time to happen but with a good A/F ratio you proboly wont have a problem
i also think alot of these "advanced timing" "running race gas" precations are not as necisary with a max because of the advanced combustion chamber design lessens detonation alot more that lets say a chevy 350 or ford 302 with stock low efficiency cylinder heads which are more likely to promote detanaiton
LilVito
Oct 25, 2019 08:12 AM
kjlouis
Nov 24, 2018 06:09 AM
Ben2003GLE
31
Jul 17, 2016 08:13 AM
Starrider
Sep 17, 2015 07:26 AM
doobadoo
Aug 15, 2015 06:43 PM
