Removing Side Marker Light Bulb
Old Apr 4, 2005 | 01:09 AM
Umass021's Avatar
I wanted to know how to remove the side marker light. Not the turning signal or parking light, I am talking about the one that lights up when you put your signal on. Only on 95-96 model. Does anyone know how to change the bulb?
Old Apr 4, 2005 | 11:48 AM
Umass021's Avatar
Does anyone know?
Old Apr 4, 2005 | 01:22 PM
theshawn's Avatar
the Light is among you
Ok, first you say it's not the turning signal light but then say it's the one that lights up when you put your signal on? Huh?
When I changed to clears on my 99 I just stuck a flathead screwdriver between them and popped out the smaller housing. After that it's SOP.
Don't know if that'll help.
Old Apr 4, 2005 | 01:23 PM
max_speed97's Avatar
I think he means the one next to the headlight
Old Apr 4, 2005 | 01:28 PM
renatonetmail
Owner manual its basically self explanatory.... knock yourself out.
http://www.courtesyparts.com/nissan-manual/index.html
Old Apr 4, 2005 | 01:43 PM
jblinga's Avatar
Yes, this is the parking light/clearance light. Not the side marker.
If you have a couple of elbows you can change it w/out removing the housing itself. If not, just take out the one screw the holds it to the headlight then use a long flathead screwdriver to pop out the stud that presses into the body. Use a flashlight to make sure you're right on the stud, or just pull the thing out but it might break if you do it that way so be careful!
Old Apr 4, 2005 | 02:56 PM
Umass021's Avatar
Thank you very much for the info. I just took it off and put some nice bulbs in there.
Old Apr 4, 2005 | 03:01 PM
jblinga's Avatar
Word up!!!
vingodine
45
May 21, 2016 12:46 PM
rtirbany
Sep 8, 2015 11:46 AM
homeyclaus
Sep 3, 2015 06:15 PM
98nismomax
Aug 13, 2015 12:44 PM
papo99
Aug 9, 2015 07:32 AM
