How to take rear door apart???
Old Apr 14, 2005 | 12:56 PM
99 SE-L
Hey guys iam int he middle of installing new rear speakers in my 2002 maxima i have took off the wndow switch and took out the ashtray/holder but i do not know what else to do please help me out....
Old Apr 14, 2005 | 01:05 PM
TheBigDu's Avatar
http://forums.maxima.org/showthread.php?t=395127
Any reason you're reposting yourself?
Old Apr 14, 2005 | 01:12 PM
99 SE-L
Becuase i could not find it now and i still dont understand how to take rear apart i took off the window switch and astray and the screw now there is hole whats next??
Old Apr 14, 2005 | 01:18 PM
99 SE-L
could u explain to me on how to do it
Old Apr 14, 2005 | 01:19 PM
TheBigDu's Avatar
4) Feel around on underside of door trim and you will feel a small gap in which you can place your fingers. This part is kinda tricky. Put your fingers in there and pull to disengage the lower clips. Just don't yank too hard or some clips might break. Then work your way around the edges of the trim to disengage all clips. There are a total of 5 or 6 I believe. You will eventually be able to just lift the panel up and out.
Old Apr 14, 2005 | 01:25 PM
99 SE-L
Yeah i see those clips i tried the first time to push them down with a screw driver
Old Apr 14, 2005 | 01:26 PM
TheBigDu's Avatar
I'm not sure what you mean by "push them down."
Old Apr 14, 2005 | 01:30 PM
XGaSpAcHo
you need to pull on the door trim. no screwdriver is necessary.
Old Apr 19, 2005 | 07:53 PM
nyautostyle's Avatar
pull the door trim toward yourself, be careful the clips could break and that would be a b!tch. There should be 3-4 clips on the door. also did u take the trim off from the door handles? that could be blocking it also.
matts95max
Apr 23, 2025 10:44 AM
AcuraLegend
Oct 17, 2016 08:47 PM
AcuraLegend
Sep 22, 2015 04:22 PM
doctorpullit
Sep 10, 2015 06:33 PM
