rotor width tolerance
It should be imprinted on rotor itself... either on the outer diameter or on the inside face...
If you've never turned the rotors before, you shouldn't have problems turning it at least 2-3 times... depending how much was taken off each time on the Lathe..
Originally posted by danielbu
What are the tolerances for rotor width on the stock rotors? ...
Rear rotor, minimum thickness 8mm.
Front rotor, maximum thickness variation 0.01mm.
Rear rotor, maximum thickness variation 0.02mm.
Use a micrometer
Thanks for the specs Dan, now to find some verniers. ...
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
