bad weather, quick alternator question(s)
I'm sending a price/spec request form to splmax.com for a new HO alt around the 250 amp range (gives me some overhead for a bigger system), and need some info on the alt, but its too nasty outside for me to go look at the alt myself, I would appreciate it if somone could tell me the:
VG factory alt model number, number of grooves on the pulley, pulley diameter, the mounting style (spool, transverse, or saddle..I've looked at the alt, but I didn't realize there were technical terms to how its mounted
# of pins (harness on the alt if applicable)
Any or all of this info would be of great help and make me happy..for awhile
)# of pins (harness on the alt if applicable)
Thanks, that fills in everything but the way its mounted (I dunno what the difference is, their little worksheet asks for it though) I might just send them a picture of it if no one knows if its mounting style is spool, transverse, or saddle..that would give me a chance to find out if they have a clue what they're talking about
you can't fit enough stereo into a 3rd gen to need a 250a alternator.
i'm running 3 large amps at full tilt and my voltage doesn't drop below 13.5 at a stoplight with my headlights and heater on. that's with a 120a alternator on my vg.
I want enough headroom to run a 200+AH rear battery bank, a 6000 watt inverter, 4 LCD screens, undercar neon (not LEDs), 3500w RMS in stereo amplification, interior neon, AND if I ever decide to, my ham equipment, which will hog up a LOT of power, as class A linear amps are VERY inefficient...
Hey man, a 250 amp alternator sounds like something that I'm interested in right about now...
I have an Optima Yellow Top battery and a 140 Amp circuit breaker which then splits into 3 (80 amp) fuses at the distribution block for each of my amps (1000 and 1600 Watts) and for my compressors for the air ride (2 - 3/4 HP compressors)...
When I have the system bumpin and the compressors kick in the circuit breaker clicks off
...I need a bigger alternator to get rid of this quick! I was going to have a custom alternator made a while back but I never got around to it, then it was winter and the Max was under her cover for the season.
I'm sending a price/spec request form to splmax.com for a new HO alt around the 250 amp range.
Can you let me know the cost??
BTW, Irraggi has a group buy on caraudio.com and quoted me $420 shipped for a 220 amp alt with a lifetime warranty.
those'll be cheaper than these Ohio Generators, which are going to run 700+ atleast...I can't afford an alt right now anyway, so I couldn't get in on the group deal..least I doubt it..the ohio generators that splmax.com sells will probably run 700+ for a 200-250 amp alt
FlaMark
25
Aug 28, 2015 10:15 AM
JMag90
Aug 25, 2015 09:17 AM
doobadoo
Aug 15, 2015 06:43 PM
