Puzzled By Wastegate
Old Apr 23, 2005 | 12:53 PM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
Im in the market right now for a tial 38mm wastegate. Now the thing that confuses me is this whole spring deal. Now i know 1 bar spring can hold up to 14.5 psi, does that mean if i want to push 14 pse that im gonna need the 1 bar spring? Or am I wrong or missing somethig here? Any help is appreciated, and please if you are boosted can you state what mm wastegate you use and what bar spring?
Old Apr 23, 2005 | 12:57 PM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
No, basically the spring size - is the maximum boost that would be achieved with no boost controller installed. Also - the spring size is the lowest boost that the boost controller can set as well.
Old Apr 23, 2005 | 01:04 PM
So technically i can get a 6 psi spring and a boost conroller and be happy?
Old Apr 23, 2005 | 01:10 PM
turbomax97's Avatar
yeah - thats basically what I have. without the boost controller i'd hit between 6.2 6.7 psi. With the boost controller - whatever my boost greedy heart desires.
Old Apr 23, 2005 | 02:21 PM
Nealoc187's Avatar
SLOW
What he said. Also they do suggest that you run a wastegate spring close to your boost controller setting however. Like don't run 20psi on a 5psi spring, etc, or you might get some issues (don't know the specifics, that just what I've read).
Old Apr 25, 2005 | 07:07 AM
mtcookson's Avatar
basically, using nealoc's situation, if you had a 5 psi springs and tried running 20 psi using a boost controller there's a chance that you won't reach the 20 psi as the 5 psi spring wouldn't be able to keep the valve closed. this would be due to high pressure in the exhaust overpowering the spring. that's my understanding of it.
Cotozic
Jun 28, 2017 08:01 PM
Ironlord
May 25, 2002 06:45 AM
kvzeyde
Jan 29, 2002 01:03 PM
BrianV
36
Jun 4, 2001 12:06 PM
