245/40/18 for our 4th gen...will it work?
I saw a set of 18" rims that come with 245/40/18 Nitto nt555 tires. Tirerack recommends 235/40/18. Will the 245's represent a problem with rubbing, or any other driving scenarios? Also, how good are Nitto nt555's? Thanks. I have a couple links here as to both tire and wheel, what do you guys think about the wheels for the MAX?
Link to rim info:
http://www.konigwheels.com/catalog_p...ID=1&ss_id=214
Link to tire info:
http://www.epinions.com/content_105286372996
Link to rim info:
Link to tire info:
They'll be fine in back. But in front, even 225's stick out from under the fender. I grab'd a used set of G35C wheels which are staggered 225/18 in front and 245/18 in back. I personally like how the 225's in front are "slightly" out. Gives it a wider and slightly meaner stance w/o looking too weird.
Originally Posted by Chunger
adding to the above... try to stay as close to an offset of 38-40mm. I have 35mm and it's OK.
Originally Posted by abradic
Sorry to sound like a newbie, but by the offset do you mean the lip?
Well, the good news is the Konig customer rep said the Konig Imagine Wheel will fit a 99 Maxima SE and the offset is 38mm which Chunger says should be ideal. Now to finalize a deal I found on ebay...the rims and Nitto nt555 245/40/18 tires for around $800. I think it's meant to be because the guy selling them lives here by me in Chicago so I can check it out before purchase!
Thanks for the great input everyone.
Well, I am out of luck on the ebay Konig wheels I found because the bolt pattern is different than what I need. Thanks Cefiro, but I would much rather put on Good Year Eagle F1 GS3's which I can get for around $500 in a 235/40/18 through my friend's shop.
I have 245's on the front, and they are recessed about 1/4". Some local guy is running like 265's and they fit!
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
ViciousVQ30
Aug 5, 2015 05:40 PM
