Increasing turn signal speed?? Anyone know how?
Other than adding blinker fluid
What would you need to do to make your turn signals blink faster? I've done the side marker mod and would like more speed on the blinks.
What would you need to do to make your turn signals blink faster? I've done the side marker mod and would like more speed on the blinks.quick enough. Using your left, instead of right, hand every once in a while
should fix you right up.
There is a way to make it faster or slower. You have to use a rheostat. its complex and hard to explain but if you know something about wiring you will do fine. basically you have to control the ground signal to the flasher signal with the rheostat.
I guess I have now officially heard it all. When one feels compelled to dwell on the speed of their turn signal, they should be officially given some kind of an **** .orger of the year award and not be compelled to relinquish it until someone with a more inane hangup comes along and strips him of the title.
from what i heard from my honda homeboy- alls you gotta do is cut some wire. there is a reason that it blinks extra fast when a bulb is out, so you know its out. but there is a way to get it blink that fast all the time (well when your signaling at least), just make it think there is a bulb out. i dont know what wire it is, just get a test light, take out one of your blinker bulbs, and test away. im not sayin this will work on a quality car, but it worked on my friend's honda
Originally Posted by Iron Scimitar
faster blinkers increase torque y0.
But seriously, why would ppl want to have their blinkers blink so fast? WHY?
It's somtehing to do instead of
Once you get to this point, maybe you should just do it!!
chernandez1278
Sep 16, 2015 01:18 PM
