5th gen starter on 4th gen?
My 98 is making the screeching sound on startup that I believe is the starter. I know I could probably do the re-grease procedure described herer http://www.motorvate.ca/mvp.php/516 but I found a good deal on a 5th gen 2000 starter. Will it work?
I seem to remember a thread about this a while ago and something about teeth count, but I don't remember if would work or not.
thanks guys/gals
ila
thanks guys/gals
ila
the 5th gen internals are put into the 4th gen starter case, the teeth are a lot differnt and it makes more torque for easier starts. I got mine swapped at by Jeff at Maximum Tuning, and i couldnt be happier!
btw just taking a 5th gen starter and trying to bolt it up will not work, im not sure about the 2000-2001 since they have the same block but i know the 3.5 starter wont work
Originally Posted by MAXRB8
Just get a 4th gen starter but make sure it has 10 teeth instead of the 8. straight bolt on. The starter with 10 teeth is the newer more HD use, better, stronger performer.
exactly, you dont do the swap yourself, you buy it like that
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
