Car starts fine when it is cold out. When it is warm,.......
the car doesn't want to turn over. It just sits there trying to start, and I have to give it gas to get started. I replaced the starter, because it wen bad and I was hoping that it would take care of this problem as well. No luck.
Dirty fuel filter?
Thoughts?
Dirty fuel filter?
Thoughts?
Originally Posted by Jeff92se
Do you know if the cold start program uses either the cam angle or crank angle sensor? Or if when hot, what does the ecu use to start the car?
I had the same issue where my car was running 1 or 2 hours prior in warm weather and wouldn't start. It would crank but it wouldn't turn over. If I let the car sit for a hour longer it would start perfectly fine. I replaced the fuel filter with no luck, but it turns out it was the camshaft position sensor.
Originally Posted by TheGuss
is it starting, then stalling?
No, once it is started it is fine. Until I turn it off again, then I go through the same process again. It's pretty embarassing.
Thanks for the replies guys, I'll look into the sensors.
Lakersallday24
Jun 16, 2019 01:35 AM
