B&M short throw shifter owners....STEP INSIDE
Old May 6, 2005 | 10:29 AM
Jonny98max's Avatar
i was able to get some time to install my B&M sts.....after driving around i have noticed that shifting into 3rd in pretty hard......its hard to find 3rd and sometimes difficult to put it into 4th too.....
anyone else havin these problems???
i am running regular gl-4 gear oil but i just pruchased 5 qts of Redline MT90.....will the synthetic gear oil solve my problem?
Old May 6, 2005 | 10:44 AM
ZeroCool19's Avatar
its going to be a "notchy" feel man, ive noticed going into 3rd was a little more difficult then the other, but not 4th, i dunno man. u install yourself? i had my mechanic do it
-Brendan
Old May 6, 2005 | 10:47 AM
96mAx2fast's Avatar
WHen i bought mine from sportcompactonly.com Steve told me to get that MT90 and it would help shift. Im shifting pretty smoothly.. Did you put everything on the right way?? i hope you didnt have any spare parts.. lol.. I did mine and everything seems fine. Someone mentioned to me that if you tighten the bolt too much that it would be hard to shift.. Overtightening might of done it. Thats all i can think of.. Check if MT90 helps!!!
Old May 6, 2005 | 11:22 AM
96white's Avatar
Let me drive it jon, I will see whats up. i think your problem is your pulling it towards your body rather than straight down. let me know if you want me to come by. for 3rd just push straight up from 2nd and it goes right into 3rd. 3rd to 4th pull STRAIGHT down. It takes time to get used to.
Old May 6, 2005 | 11:47 AM
MrEous's Avatar
^ Jeff™
Practice practice practice...you just got it installed, thus throwing off what you are 'used to' doing as far as shifting.
I have -0- problems finding 3rd or 4th. About 20k miles after I installed my B&M shifter I changed out to MT90 gear oil and it was a little less notchy.
I've driven a Max with the stock shifter and it is a world of difference.
...although if you still experience this problem maybe you have tranny problems.
Old May 6, 2005 | 12:57 PM
96mAx2fast's Avatar
POWER to my fellow pebblebeigers!!!!!! lol.. Im thinking about doing the mt90 thing but i feel my shifter fine.. i had an RX7 before this and nothing is worse than shifting that thing, thats why i guess i feel it ok.. Is the difference BIG w/ mt90??
Old May 6, 2005 | 01:00 PM
MrEous's Avatar
^ Jeff™
It's Sterling Mist D4mnit!!!
Lighting throws it off...hahaha
Old May 6, 2005 | 05:46 PM
SPiG's Avatar
SomePsychoGuy
How long have you had it? For the first 2 weeks or so it is pretty stiff. It has to break in.
MT90 will help. There is also the "Dave B" shifter mod that helps shifter feeling.
Old May 7, 2005 | 01:15 AM
Jonny98max's Avatar
i think i just need to get used to the new shifter.....im waitin on my mt90....hopefully that will help a bit.....
Old May 7, 2005 | 06:41 AM
99se5spd's Avatar
the mt-90 will make a noticable difference, although nothing drastic. mine took almost a month until it loosened up. i had to adjust the bolt/nut where the shifter meets the linkage a couple of times, the first time it was too tight, than too loose, finally got it right and threw some lock-tite on there to keep it in place. i also greased up that plastic bushings with high temp grease.
Old May 7, 2005 | 06:43 AM
tomservo291's Avatar
I had my gear oil changed with regular ol' GL-4 at a oil change place a few months before I bought my B&M.
It was notchy and stiff for ~ 2 weeks of driving, now its the smoothest shifter I've ever used. No special gear oil here, just plain old broken in nicely (my tranny only had 60k on it at the time of install too, but I don't think that would make any difference.)
It will loosen up, give it a chance.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
atriuum
Sep 28, 2015 01:19 PM
