300ZX BBK Installed "PICS"
Old May 8, 2005 | 11:38 AM
japmaxSE's Avatar
Go Get a Life!
300ZX BBK 13" Xdrill slot Cobra Installed "PICS"
What do you guys think of the color? My friends say they look like Brembo's from a distance.
Old May 8, 2005 | 11:42 AM
japmaxSE's Avatar
Go Get a Life!
It was alot of work, I stayed up till 4am last night.
I still have some clearance issues with the left side .
I had to buy longer studs, wheel spacers and a whole bunch of bolts and washers.
Kevlo911's Avatar
Kevlo for President
Looks good, now paint that bumper
Old May 8, 2005 | 11:47 AM
japmaxSE's Avatar
Go Get a Life!
OH I forgot to mention there 13" Cobra rotors...
Old May 8, 2005 | 11:50 AM
gtr_rider's Avatar
192.168.1.1
Hotness.. now put that tranny in,
Old May 8, 2005 | 12:15 PM
2 Da Max's Avatar
how hard was the install? looks hottt
Old May 8, 2005 | 12:32 PM
Maximeltman's Avatar
dope! i wanna do this also, but im currently strapped for skrills...japmax, how much u have to spend on the calipers and reloc brackets? and were the rotors drilled to max spec or no? what offset wheels used? sorry bout all these ?'s but i need ta know!! great job!
Old May 8, 2005 | 12:58 PM
japmaxSE's Avatar
Go Get a Life!
It was Kind of hard In my case my 18's width was to close to the center of the wheel "deepdish" and it wouldn't fit I had to get some wheel spacers other than that longer studs and a little bit of grinding. OH and there is a trick to get that dust sheild off after spending an hr on the first one I figured all I had to do was Bang on it left to right break it loose and get some metal cutters and cut one end and bend it off it took like 5 min . You can get the reloc brackets from Jeff and the SS lines from MaTT Blemco Here's a link to some GD's you will find most of the things needed here if not ask Jeff or MAttBlem, I'm not to familiar with some of the setups I did this one with Jeff's brackets and Matt's SS lines I had to drill holes to match factory specs cause no one has the rings to buy from,,, Jeff has a set but he's currently trying to find a machine shop to machine them.
http://forums.maxima.org/showthread.php?t=396095
2 Da Max's Avatar
uhm, i cant find the fawken write up. any links?
Old May 8, 2005 | 01:22 PM
where u get the calipers from? theyre gold too? nice...
2 da max...check out blehmco.com
Old May 8, 2005 | 01:23 PM
i mean mattblehm.com
Old May 8, 2005 | 01:44 PM
japmaxSE's Avatar
Go Get a Life!
It's just High Temp Gold Paint from PEPBOYS
I got the cals for $80 at a local J/Y.
Old May 8, 2005 | 01:45 PM
2 Da Max's Avatar
80!! wtf thats not bad at all bro
Old May 8, 2005 | 02:13 PM
omp gah
japmaxse i was thinking about doing the same mod and i was wondering exactly what you used for the install?
30 or 28mm calipers?
steel brake lines?
did you use the mattblehm bracket to fit the calipers?
also what size wheel spacer did you use?
Old May 8, 2005 | 02:16 PM
Puppetmaster's Avatar
Those look great... more incentive for me to hit up some junkyards this summer...
Old May 8, 2005 | 02:45 PM
japmaxSE's Avatar
Go Get a Life!
steel brake lines?
1. 30mm Alumn cals $80 J/Y
2. SS lines from MATT93se $50 shipped
3. Jeffs brakets $45 shipped
4. I used 4 spacers each wheel I think it was like 1.2"
Spacers were a Freebie got them at work.
5. 13" xdrill slot Cobra rotors both $95, Local
6. Bolts, washers and longer lugnuts Total $50
I put it together myself I don't have any writeups, I just went along wit da flow...
Old May 8, 2005 | 04:03 PM
omp gah
alright thank you, whos jeff? and matt93se? and also did you just do the front of your car and not the back? and where did you get the rotors?
Old May 8, 2005 | 04:15 PM
|Bijan|'s Avatar
UCF Lexus
sweet, I want to do this
Old May 8, 2005 | 04:52 PM
omp gah
japmax can u get me the number of some junkyards?
Old May 8, 2005 | 05:34 PM
diiesel21's Avatar
do you have to change your master cylinder if u have abs when do you this conversion?
Old May 8, 2005 | 06:11 PM
jblinga's Avatar
Looks good!
Old May 8, 2005 | 07:20 PM
japmaxSE's Avatar
Go Get a Life!
In MIA all the good J/y's are on 135th st it's well known down here for parts over thousands of cars ranging from brand new to old. The only way your going to get the best out of these J/y's is to be here and actually go in don't talk to anyone because most of them don't even know what they got. For instance I asked one of the owners and said do you have any 300zx cals he said ummm NO I said are you sure ,,, NO! I was like hell nah there like thousands of cars in your lot you don't have one ZX. So I took it upon me and walked right in the yard and beleive it or not it was sitting right there in perfect condition.
Old May 8, 2005 | 07:23 PM
japmaxSE's Avatar
Go Get a Life!
Car-Part.com its a great source for parts
Old May 8, 2005 | 07:30 PM
japmaxSE's Avatar
Go Get a Life!
I got the Rotors here through a friend of mine.
Rear Xdrill , ss lines next week .
Jeff92se:http://forums.maxima.org/member.php?u=141
Matt93se:http://forums.maxima.org/member.php?u=46
Old May 8, 2005 | 07:36 PM
PandaXpress's Avatar
why is the fender discolored from the rest of the car?..looks funky...and its not aligned properly..no offense.
Old May 8, 2005 | 07:39 PM
Maximus_95's Avatar
looks good
Capital15's Avatar
Looks really good. Nice job!
Old May 8, 2005 | 07:42 PM
TheFink's Avatar
Very nice look!
Old May 8, 2005 | 07:46 PM
japmaxSE's Avatar
Go Get a Life!
Uhh accident..
Old May 8, 2005 | 07:50 PM
Magikone69's Avatar
looks gr8, same thing i would have done if my calipers fit under my wheels, i love the color. i coulda sworn the last time i saw your car you had a painted bumper, what happened.
O/T
if anyone needs 300zx calipers i have an aluminum set for sale in the parts for sale forum, i already have dibs but check it out and let me know if you are interested. 30 mm aluminum calipers
Old May 8, 2005 | 08:17 PM
rastab97's Avatar
sweeeeeeeet niice job. any major problems?
Old May 8, 2005 | 08:20 PM
japmaxSE's Avatar
Go Get a Life!
drunk friend hit me now I got a 99 bumper.
Old May 8, 2005 | 08:21 PM
japmaxSE's Avatar
Go Get a Life!
nothing major.
Old May 8, 2005 | 08:58 PM
GoalieKeg's Avatar
Looks great fred! I'm almost finished with my BBK too...mabye I'll post it up in a few days.
Old May 9, 2005 | 03:39 PM
Jeff92se's Avatar
I'm needing a caw
Bed the brakes and let me know how you like it.
Old May 9, 2005 | 03:58 PM
Max4U's Avatar
First I would like to say those brakes look beautiful on your car japmaxse. And second, I would like to let everyone know that I have the whole set up for sale. It was used for only one day. $530 Shipped. Everything was bought new, and the calipers are remanufatured with brand new pistons and stuff. thomaspc7@aol.com
Old May 10, 2005 | 04:19 AM
omp gah
japmax how much would it be to powered coat the calipers?
Old May 10, 2005 | 06:10 AM
WielkiWaac's Avatar
MaximaDriver
Looks nice
Old May 10, 2005 | 06:23 AM
brad kay
looks awesome! nice work.
Old May 10, 2005 | 10:31 AM
lilaclucymaxima's Avatar
Team Ramrod
Looks awesome man .
