need some data or info...about ecu tune (those with the JWT S/C program)
Old May 9, 2005 | 06:17 AM
michaelnyden's Avatar
those of you with the JWT S/C program....what is your AFR across the board at WOT and what is your timing as well?
also, what would you change to get more power out of the S/C program but still be able to use 91 octance on your S/C'er setup? I need some of this data so I can have a custom program made at technosquare...basically make the perfect program from your input on what timing and A/F you guys would want...but still be able to run on 91 octane (I live in CA...so no other option really)
ie. I know most of you state the JWT S/C program has a very good A/F tune @ something like 12.5:1 but it's timing is way to conservative...
Old May 9, 2005 | 06:36 AM
Stephen Max's Avatar
JWT developed their tuning parameters based on extensive dyno testing of turbocharged 300ZXs running at much higher boost than what we Maxima owners have been running. So a timing map developed for safe operation of a 300ZX running over 20 psi will be quite conservative for Maximas running in the 10-16 psi range. I don't think it is ultra-conservative, since most of us are running the stock 10:1 compression ratio as compared to the lower CR of the 300ZX TT. Nevertheless, I very much like having the peace of mind knowing that the timing maps are not right at the hairy edge of detonation and I might burn a hole in a piston the next time I dyno or do a WOT run on the highway on a hot day.
Apparently, though, they have raised the afr from 11.5:1 in the 300ZX turbo program to 12.5:1 for the Maxima SC program. I consider this is a good thing, because power is optimized at 12.5 and starts to drop as you go lower.
My only complaint is that the afr doesn't drop to below 13:1 until after 5000 rpm, from what I've seen from my WBO2. I called JWT about this and they maintain that the afr is actually lower than that and I am seeing a higher afr because of intake charge blow-through during valve overlap. That may be true, but I adjusted the afr downward in the 3-5 krpm range with the SAFC and got a little more power.
Old May 9, 2005 | 06:01 PM
how much did you get in the mid range there? and how much did you richen it? so until 5K, the AFR is higher than 13:1, then it drops from there? it's not 12.5:1 across the board till redline even from the low-end?
Old May 9, 2005 | 06:08 PM
I30tMikeD's Avatar
13:1 until until 5K rpms? I talked to Ben at JWT last week and they said the shoot for 11.5:1 and their turbo tune and it is the same as their SC tune. Mardi said his was 10.5:1 right out of the box with no other corrections. I do not want anyting higher than 12.5:1 at any point in my AF ratio. 11:1-11.5:1 is what I am looking for.
Old May 9, 2005 | 06:37 PM
that is way, way too rich!!! I think 12.5:1 is still safe on 91 octane!...you can get away with such cause I hear the timing is so conservative!!!
has anyone on here ever data logged or graphed the timing on the S/C program? I need some kind of timing data to use when I visit technosquare...
Old May 9, 2005 | 07:11 PM
I30tMikeD's Avatar
11.5:1 is not way to rich in any way at all. That is a very common AF ratio that much better tuners use than Jim Wolf. For a SC set up that does not see boost till redline 12.5 is fairly safe in the lower part of the rpm band. But with my turbo I see peak boost at 4K rpms and it holds till redline. Much more power being put down much earlier with a turbo
Old May 10, 2005 | 01:13 AM
I meant 10.5:1 is too rich...what mardi saw "out of the box"
Old May 10, 2005 | 05:48 AM
The afr stays in the 13s till about 5000 rpm, then gradually drops to 12.5 at 5000 rpm to 5500 rpm.
I added 10% from 3000 to 4500 rpm, and 5% at 2500 rpm and at 5000. I gained about 5 lb-ft of torque from 3-5 krpm doing that.
Mahmuth
Aug 16, 2024 08:23 PM
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
gigabyte
Jan 6, 2017 06:05 PM
Socalstillen
Sep 26, 2015 12:01 PM
