O2 Clamp for "lean tip-in"
Old May 10, 2005 | 02:43 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
This guy sells a $40 O2 Clamp + a $20 pressure switch(or maybe Stillens' Hobbs Switch?), so you can avoid lean tip-in which is when you boost during partial throttle, closed-loop, and the ECU tries to fight the richer ratios then stoich before it enters open-loop. If you've ever experienced pinging/detonation under light throttle, this is probably why...
Originally Posted by olderguy
... O2 clamp which feeds a lean signal to the stock ECU as you enter boost so that the ECU does not see the fuel added by the Emanage or AFPR and reduce the duty cycle of the injectors to try to bring the mix back down to stoich.
It would be great if somebody with a WB02 *COUGH**StephenMax**COUGH* would log this "lean tip-in" and implement this guys solution....http://forums.maxima.org/showthread....=1#post3969929
Old May 10, 2005 | 03:36 PM
sx7r's Avatar
i actually bought a pressure switch a couple weeks ago to do just this, since i was running lean at partial boost below 4k rpm due to closed loop. except, instead of clamping the O2 voltage, i was going to either cut O2 voltage or activate an O2 simulator upon boost. I just haven't gotten around to wiring it up. nice to see that i'm not the only one with this problem.
as far as logging WBO2 goes, it's pretty straight forward. my FJO always reads around 14.7 when i'm in partial throttle, partial boost, below 4k rpm. Above 4k rpm, i'm around 11.0 to 1 AFR.
Old May 10, 2005 | 06:44 PM
subs1000w's Avatar
a pressure switch with an O2 sim would be a very basic and effiective way of solving the problem
just rig up a relay the presure switch trips when in boost to switch the O2 wire or for 4th gens 2 wires
Old May 10, 2005 | 08:54 PM
subs1000w's Avatar
the setup could look somthing like this
also heres a page that shows how to biuld a basic O2 simulator for about $20
http://www.mkiv.com/techarticles/oxy...sor_simulator/
jmlee44
Oct 2, 2022 02:13 PM
MAXSE5SPD
Sep 17, 2022 04:00 AM
maxima297
Sep 24, 2015 08:57 PM
ajahearn
Sep 19, 2015 03:03 PM
followthadollar
Sep 13, 2015 09:55 AM
