1/4 and 1/8 Mile Racing Talk about track times, launch techniques, strategies, etc. Check out the "Timeslips" subforum for posted times.No discussion of street racing will be tolerated.
I'm improving
Old May 14, 2005 | 06:11 PM
Loe max's Avatar
I'm improving
Todays conditions aren't what I'd call Ideal, but I headed out anyways.
Temp 56degrees
Winds west at 28mph with 33mph gust (headwind)
Humidity 66%
Track elevation above 3,000 ft.
I finally figured out how to get a decent 60ft time with shallow staging. This time I figured I'd prepair myself better so I dropped my front tires to 25psi and removed items in my trunk. I also changed out the Bosch Platinum 4's with NGK-Vpower and there doesn't seem to be a difference running through the gears, only at lower rpms if even slightly. I only ran a total of 5 times, two runs where I actually didn't misshift unfortunately. I couldn't for the life of me find 3rd gear for some reason but on those runs I still scored similar 60ft times.
My best two runs:
Reaction .043
60ft 2.377
100ft 0.000
1/8 9.998
MPH 71.612
1000FT 12.985
1/4mile 15.497
MPH 90.114
Reaction .014
60ft 2.273
100ft 0.000
1/8mile 9.921
MPH 71.950
1/4mile 15.312
MPH 90.806
How much could that 28-33mph headwind effect my times, especially my trap? I couldn't get above 91mph like I have in the past.
Launching techniques 2,500rpm slip clutch. I shallow staged letting out the clutch to get the car moving without chirping on the last yellow light and s split second later I let out the clutch quicker, getting off the clutch at I would say 2,800-2,900rpm to get a nice squeal and went WOT without traction issues.
Old May 14, 2005 | 08:13 PM
JClaw's Avatar
Nice reaction times. I need to get consistant ones in the .000-.050 range for bracket racing.
Looks like the headwind was setting you back about 1 mph. You could do 15.0-15.1 the way you drive. You second time is similar to a run I made when I was stock. 2.264 60' and a 92.05 mph trap speed resulted in a 15.07 with a sh*tty, way too low 2-3 shift. a 2.300 60' and a 91.78 mph trap speed resulted in a 15.00 with good shifts. Pull that 2.27 again and with a very high 91 or low 92 mph trap speed it would be possible to see a 14.99.
My launch technique was a 1,800 rpm granny clutch dump, which netted consistant 2.30-2.35 with the 2.26 being a fluke. It also resulted in a .022 R/T and quite a few in the .040-.080 range. I shift at redline in first and gradually lower for the rest of the shifts.
Old May 14, 2005 | 09:23 PM
Loe max's Avatar
I try to land my shift points at indicated:
6,600rpm 1-2
6,300rpm 2-3
6,200rpm 3-4
It doesn't make a difference if I shift or leave it in third but I normally shift to 4th.
Old May 21, 2005 | 05:05 PM
fmaru's Avatar
i shift to 4th as well and I have more success that way
Old May 22, 2005 | 09:33 PM
Mr.Duck's Avatar
those are your stock times? not bad at all. I dont shift into 4th, but i may try that next time
Sep 27, 2015 08:37 AM
msellas
Sep 23, 2015 09:16 PM
carid
Sep 9, 2015 05:06 AM
Maxboy23
Sep 4, 2015 06:04 PM
