'01 in '97 tranny swap (problems?)
Hey all,
Finally got my car back with new '01 5spd tranny, ACT stage 1 clutch kit, and Fidanza flywheel....I love it, but i think there's a problem with my speedo. It seems to be off about 10% or so. Any ideas on what's causing this? Some things I've thought of so far are:
- My mech. put in the speed sensor for my '97 and it really needs an '01 speed sensor?
- New gear ratios on the '01 tranny as compared to the '97?
- I'm also pulling CELs for knock sensor and MAF sensor....could this be related?
Any input would be greatly appreciated....thanks!!
-Jon
-Jon
Originally Posted by tmkforever
Hey all,
-Jon
-Jon
also i really doubt that the speed sensor would cause your knock,maf sensor to go. so get your haynes manual and a muti meter and test those's two sensors that you have a check engine light for
Yeah, how do you get that your speed is off 10%.
I've had my 01 tranny now for over a year but have never even thought to question the accuracy--I have no way of knowing. My 01 tranny had no speed sensor--had a factory plate covering it--so had to use my '95 speed sensor.
Originally Posted by JDM_Maxima
congrats on your tranny swap. as far as the speedo, many 00 and up trannys use the abs sensor for the speedo. its our 4th gens that have a sensor coming strait from the tranny that tells how fast your going. how can you tell that your speed is off about 10%?
Originally Posted by nismos14
wow how much did all that cost you? parts included
- $825 for '01 tranny with 50k mi
- $375 for ACT stage 1 clutch kit
- $360 for Fidanza flywheel
- $50 for Red Line tranny fluid
- $600 for installation
so in total....$too much
Uummm...too much, lol.
Not to threadjack, but...
I own a 300zx TT and need a RELIABLE daily driver. I've been considering purchasing a 95 5spd Maxima with 76k miles, but I'm scared to death after reading about the transmission bearing problems. Anyone care to elaborate on the estimated amount of cars with this problem?
Well, mine started to leak at around 80k. If I were you, I would check for oil around the driver's side axle that is smeared on the tranny case. The I would go underneath and check the end of the axle that goes into the tranny for any free play (there shouldn't be any). Then I would drive the car and note whether you hear and metalic creaking noises when starting in 1st or 2nd gear. If the 95 passes these, you should be golden for many many miles. Just be aware that you potentially have other issues in a car that is 10 years old: rear main seal, knock sensor, O2 sensor, coil packs, water pump seals and some smaller items: ignition switch, starter, engine coolant temp sensor, etc. that have been known to fail in the 4th gen maxima. All in all, nothing too terrible as long as you avoid the tranny bearing problem. I personally use my 95 as my daily beater and almost every time I drive it, I am thankful to have such a capable car as my beater.
Hey all,
-Jon
-Jon
Would you agree that I would be better off trying to find a low mileage 97-98 model?
Originally Posted by maxiquin
i have a 95 fully loaded se with 130k miles on it. neva had one problem with the tranny!
Do you know for a fact your tranny has no bearing problems? Because tranny fluid is thick, you don't get a puddle on the ground until the problem is severe. For 20k miles or so, the leak could be coating the bottom of the tranny with oil and someone who didn't check would be none the wiser.
some actually dont have the problem, i dont have it yet, i got my car at 120k, its now 143 and i checked the axle last week, almost zero play in it. but i dont know if the original owner ever rebuilt it. but i know a friend who has 180k on the tranny and shifts perfectly and no leaks.
speed test!
Hhmmm... what exactly does this mean? How can the ABS sensor give information to the ECU about wheel speed? I guess this mismatch might cause some problems though... 10% is just my guess.... I drove next to my friend and his speedo was reading 60mph and mine was reading about 52mph. I also had suspicions when I was on the NJ Parkway doing "60" in the middle lane and blowing by people everywhere. It doesn't seem to match up, but then when the speeds approach 80, it seems to be more accurate. I guess I can't really know without having a cop shoot me with a laser, LOL...no thanks :-) I don't have any diagnostic equipment with me so I can't check those sensors, but as soon as I have the chance I will. Thanks for the tips
pktaske
May 6, 2016 07:49 AM
pktaske
Sep 4, 2015 08:40 AM
