Weird problem
Weird problem
Ok here is my living hell... turn my key and i get no lights on the dash,no needle movement from gas,tach,temp even mileage. Also my windows will not work( will workk after the car has been running for a bit) Lights on the dash also start working after a bit of running but very dim. Rear defog switch does not work. also heat/ac blows but does not light up and a/c does not kick on.But the car will run...
Sounds like drained battery. Don't think it's the alternator but not sure as nothing posted about hard starting. To start, use a multimeter to check your fuses like smokey said to see if they are on their way out. If it's not the fuses, maybe use a battery charger connected to the battery to see if the lights come on right away. Post what happens.
ya man get a 10 dollar multimeter and download a factory service manual from my site, http://zazon.us/maxima
Ignition switch probably going out, there is a wire I think its blue and red that is supposed to have potential for things like the a/c, if not powered these accessories will not work, check with a remote start wiring diagram to make sure; but if it is not getting that contact that is made with the ignition switch they won't come on.
alright thanks. UPDATE I wass tinkering around and pulled a few fuses now here is the kicker i pull out fuse #13 with the engine running then the windows will work and the rpm gauge and everything else starts to come on then i put the fuse back and everything goes out and there is a huge load on the engine as you can hear the drop in rpm.
AaronL
Nov 15, 2020 11:52 AM
