MEVI question
Old May 21, 2005 | 10:55 AM
Spaniard's Avatar
MEVI question
Hey, can anyone confirm this:
The force that makes the mevi open is the vaccuum pressure.
The force that makes the mevi close is due to a spring mechanism that works when the vacuum pressure stops.
Thanks-
Old May 21, 2005 | 11:49 AM
NmexMAX's Avatar
dot dot dot ...
The term vacuum pressure would seem like an oxymoron ... But in a nutshell yes that's correct ...
Old May 21, 2005 | 11:50 AM
Spaniard's Avatar
damn, thats what I thought. Thanks for the info
Old May 21, 2005 | 11:51 AM
1FSTMAX's Avatar
yes..... and yes......
Old May 21, 2005 | 12:32 PM
Spaniard's Avatar
basically, this means I am screwed. My mevi sticks, and basically theres no way that I can get the spring to close the valves again. Im stuck with picking open or closed for a track session and thats it. I can get the vaccuum to open it (after like thirty sec) but theres no closing after that
I wonder if Courtesy Nissan will give me a refund...
Old May 21, 2005 | 12:34 PM
NmexMAX's Avatar
dot dot dot ...
is up w/your spring?
Old May 21, 2005 | 12:35 PM
Zack342's Avatar
you try oiling it? The would probally blame it on your install?
not to steal your thinder or anything but where did you order your relay and what rpm switch are you using?
Old May 21, 2005 | 01:51 PM
Spaniard's Avatar
I tried oiling it, it helped but nowhere near enough. I dont see where the spring is- I had it installed by Turbo95Max (matthel) and he couldnt get it to work.
I oiled the moving parts that I could get to (took the top off of it) but the fact of the matter is, there is just still so much friction that it only sloooowly opens under vaccuum (I dont have the summit switch or relay on, its just straight vaccum hose) and when no vaccum, it - stays!
I suspect that the rubber gasket in the lever is too tight against the brass "cylinder / housing". So I put some oil in there, again, seemed to help but only a little. I dont see how I can just take that part off and get it replaced, either. Can I order new butterflies / rod / arm assembly from somewhere? Anyone got suggestions?
Old May 21, 2005 | 04:37 PM
SPiG's Avatar
SomePsychoGuy
The spring is probably in the actuator thing. That is the only place I can imagine it could be in. You can call courtesy and order a new one. It shouldn't be too much.
all the MEVI parts:
http://forums.maxima.org/showpost.ph...68&postcount=5
Old May 21, 2005 | 05:56 PM
GodFather's Avatar
Made in Taiwan
aaaaaaawwww, little spaniard has mevi problems...
just joking,
yes, and yes to your questions.
mine hasn't have that kind of problems yet. hopefully i won't. if you find a solution to it, please let us know. thanks alot.
litch
123
Jan 4, 2024 07:01 PM
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
