help with oil presure and oil temp gauge
Old May 24, 2005 | 04:59 AM
maxspeed96CT's Avatar
The original VQ...
I am planning on running a S/C soon, so i need to make sure i have there hooked up ready to go.
Ok , i am going to be hooking up a electrical oil pressure gauge , i got this job down pat from the pics 1max2Nv has posted before.
but I also want a oil temp gauge tho, can i hookup all 3 senders to the one oil line?
for example can i run a line up from the stock oil pressure sender location , and then use a fitting for the stock sensor, the oil pressure sender , and the oil temp sender + the line? or will this be to much hooked up t one line?
I want to set it up like the pressure sender in this pic, but i would also like a temp sender to the fitting....
Old May 24, 2005 | 06:48 AM
slimer's Avatar
A couple of Blaxxx's? Lawls.
you can do that, but here's the deal. it would be MUCH easier to install everything but the senders now. the reason for that is that there is a line that comes out of the oil pan where the oem fuel pressure sender is. you can t that line to put any senders that you want. just run the wiring now so you dont have to do it when there is tons of charge piping in the way.
Old May 29, 2005 | 09:22 PM
The original VQ...
so i can i run a line from the stock sender location and hookup a 4 ended fitting,
-one end for the line itself
-stock oil dumy light
-oil pressure sender
-oil temp sender
can i hook all these up in one spot and a geta good reading??
Old May 30, 2005 | 08:26 PM
mtnbikeair's Avatar
Just dont hook up the stock oil light, you dont need it and if you pay attention to your car like i would assume you do you can go with out it.
Miket2006
Mar 1, 2021 03:55 AM
mclasser
22
Nov 12, 2020 01:58 PM
Apr 16, 2020 05:15 AM
05RLS2
Apr 14, 2016 11:49 AM
