mileage vs years
mileage vs years
my maxima is going to be 5yrs old in august, yet i'll only have approximately 50k miles on the car at that time. service book says the next big servicing should be a 60k miles, but by then the car will be 6 years old. is there a point where i should ignore the miles and go by years old, or is the mileage still the best indicator of service regardless of how old the car is?
thanks.
thanks.
The only thing I would be inclined to worry about is the condition of the radiator coolant. Has it been flushed before? If not, you should take it to a radiator shop and get them to do a pH test on it. All they do is stick a piece of paper in the radiator and check the color of the strip. I didn't get my first radiator flush until going on 6 years. At that time the car had 35K on it.
Radiator, hoses and belts. Hoses and belts because they tend to dry-out. Drying out typically occurs before wearing out (even if you drive 50k a year like me). Coolant because it breaks down over time. probably not a bad idea to flush and fill the tranny and break lines as well since both fluids tend to pick up water over time. Flushing and filling both systems will add life to the systems.
thanks.
thanks.
So, since you don't seem to be driving much, you'll probably want to perform the required service items based on number of months rather than number of miles.
Not all miles are created equal. I commute 90 miles round trip every day. This puts a lot less wear on the engine than one that never sees the highway. Once the engine/oil are at operating temperature, the wear that occurs on the engine is, for all intents and purposes, zero. The wear that occurs on an engine is during a cold startup and the accumulated acids and water that form in the oil from blowby because the engine doesn't get hot enough vaporize them.
I don't think you can ignore mileage or years. Everything else being equal, the engine with more miles will have more wear. An older car even if it has less miles can have more required maintainance than a newer car with more miles. This is because of things like hoses, belts, the battery, bushings, electical items,
Having said all that, mileage probably is the best indicator of the wear a car has in general.
for foobecaI used to live in Evanston, IL and work in Skokie, IL. It was about a 10 min drive to where I worked... and in the harsh Chicago winters, it wasn't even enough to get the car up to warm operating temperature. I used to have to run it for 5 min before driving it (but even this is bad, too).... but such a short distance was much more wear and tear than an even commute like he does (90 miles round trip!?? good God, man!)
Foobeca is right about not all miles being equal. If you drive your car easy and do a lot of highway cruising, then you have little to worry about. It's much harder on a car to make frequent short trips and a lot of accelerating.
If you're concerned about something, it can never hurt to change your fluids. They're all relatively simple to do and it's cheap insurance...fresh, clean fluids never hurt anything. Better to do it than not.
Originally Posted by MaxKlinger
..........Foobeca is right about not all miles being equal. If you drive your car easy and do a lot of highway cruising, then you have little to worry about. It's much harder on a car to make frequent short trips and a lot of accelerating.........
JoshG
51
Sep 21, 2015 10:41 PM
