4th gen rotors, pads and ss lines on a 3rd gen
Old May 27, 2005 | 11:15 PM
Cheocwa's Avatar
My friend is parting out his car and he has nice brembo rotors and some new pads I wanted to know if both will fit on my 94 se. I know the front rotors are the same because the part numbers are the same but I have no clue about the rear or the pads or the ss lines. I only have one day to find out so I do not have much time. Thanks.
-Larry
Old May 27, 2005 | 11:59 PM
michaelnyden's Avatar
it should all be identical as on the GD forums, under a brakes GD, found here:
http://forums.maxima.org/showthread.php?t=374496
it looks as if they are all the same except for the 02-03 (of course)...
on jerry rome nissan's site, all the rotors are the same price....the rears do have different part numbers, but when I go under the nissan fast system, it says the fronts are different part #'s and the rears are the same...basically, there's only one way to find out...try and bolt them on I guess...but I would think the rears have to be the same as the pads in the rear have the same part #'s for both years, however, the fronts have different #'s...all in all, I would think it would all bolt up...
Old May 28, 2005 | 02:13 AM
Cheocwa's Avatar
You are too funny mike. Why are you in the 3rd gen forums anyways? So I guess we should just try it then huh? park mine next to yours and swap!
Old May 28, 2005 | 09:07 AM
Matt93SE's Avatar
STFU n00b!
rear brakes are the same from 95-2003, but they are NOT the same as the 3rd gen.
in fact, the 3 gen has two different calipers and torque arms based on production date. mix them up and yo sheit don't fit.
the parking brake cables are also different for 3/4 gens.
have fun swapping if you try.
Old May 28, 2005 | 04:19 PM
well we aren't swapping the calipers, just the rotors and pads and lines...so what do you think matt?
so just do the fronts then?
Old May 28, 2005 | 10:47 PM
Matt93SE's Avatar
STFU n00b!
Can it be much clearer than that?
Old May 28, 2005 | 11:29 PM
I thought you meant the calipers won't fit cause of a different bolt pattern or something...jeese...relax...
Old May 29, 2005 | 04:49 PM
Cheocwa's Avatar
Yeah I am just taking his rotors and pads and maybe lines. So far it looks like I am just going to take the front ones. but it looks like the part numbers for the rear are the same. I guess we should just do the front.
Old May 30, 2005 | 07:09 AM
Matt93SE's Avatar
STFU n00b!
the pads are the same on the back, but that's the only thing. calipers and rotors are different.
matts95max
Apr 23, 2025 10:44 AM
MAXSE5SPD
Sep 17, 2022 04:00 AM
BkGreen97
Apr 2, 2016 05:47 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Lowered_a33
Sep 1, 2015 07:49 PM
