what is this vaccum hose for?
Old May 30, 2005 | 11:27 PM
mofoaka's Avatar
and just to let yall see my polished valve cover.. stupid stud on the head snap so i'll have to get another one... do you think i can run the engine with one missing stud on the valve cover?
Old May 31, 2005 | 03:08 AM
MrGone's Avatar
it goes on that little bypass thing on the firewall. poke around, you'll find the port.
should be ok without that bolt. Just keep an eye out for leaks
Old May 31, 2005 | 03:43 AM
Wiking's Avatar
Originally Posted by mofoaka
[IMG]... do you think i can run the engine with one missing stud on the valve cover?
Your hose is no.15.
Take a luki of u climate ctrl valve at: http://www.cardomain.com/memberpage/748507/8
15. ...........Vacuum line from intake; hose contains small oneway valve.
14. ............Magnetic valve for vacuum control.
14b. ..........Vacuum line link from magnetic valve to vacuum actuator.
14c. ...........Vacuum actuator arm moves the actual water hose (7.) valve.
14d. ...........Inset: (Mechanical) Water Valve is 'hidden' under the assembly.
16. ...........Electronic control wiring from cabin. Note the diode -mark on the connector.
Edit: ...The stud: as long as it keeps saddamoil inside its ok.
Old May 31, 2005 | 06:11 AM
DanNY's Avatar
Ad·min·is·tra·tor
looks good...now get the hood shocks replaced.
Miket2006
Mar 1, 2021 03:55 AM
conansriver
Nov 18, 2015 02:46 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
MaxDD
Sep 24, 2015 06:40 AM
followthadollar
Sep 13, 2015 09:55 AM
