13" COBRA BRAKES
Old Jun 14, 2005 | 08:32 AM
oofzpumba's Avatar
13" COBRA BRAKES
is it possible to change only the caliper? and keep the rotor that i have now?
do i have to change the master cylinder? i have no idea what this is? anyone know where i can get them? thanks.
Old Jun 14, 2005 | 08:36 AM
Jeff92se's Avatar
I'm needing a caw
Me neither.
Old Jun 14, 2005 | 08:52 AM
oofzpumba's Avatar
well is it possible to use the 16 inch oem wheels for the brake upgrades i know it says must have 17 inch wheels or bigger but anyone? try something?
Old Jun 14, 2005 | 09:18 AM
dmontzsta's Avatar
Ford Only.
I think it would be a waste of time and money. Just go for the bigger caliper too.
Old Jun 14, 2005 | 09:25 AM
Jeff92se's Avatar
I'm needing a caw
You can run the 300z caliper on the oem 300zx rotor. And it willl allow the use of 16" wheels. But you will need some wheels with alot of spoke clearance. The wheel dia is NOT the only factor.
it will also no longer be a cobra bbk.
Old Jun 14, 2005 | 09:52 AM
mb1's Avatar
mb1
did you happen to find out the clearance for me?
I just got g35 18's, and while im sure i can fit the calipers on there with the 300zx rotors, I would really like the cobra kit.
Old Jun 14, 2005 | 09:54 AM
Jeff92se's Avatar
I'm needing a caw
Beat ya to it. You won't have a problem. MEGA clearance for the 13" rotor and the wide caliper.
http://community.webshots.com/album/351324042iVJnNr
Old Jun 14, 2005 | 10:05 AM
mb1's Avatar
mb1
awesome. I'll be ordering the brackets from you shortly.
Thanks alot.
Old Jun 14, 2005 | 10:07 AM
Jeff92se's Avatar
I'm needing a caw
Unless you already have the rings, you should just go ahead and order the brackets and the centering rings for the cobra rotor at the same time. I sell both now. Price for both is $45 shipped. So $45 x 2 and you are there. The brackets are in stock. The rings are on back order for about 1 week.
Thanks alot.
Old Jun 14, 2005 | 02:20 PM
mb1's Avatar
mb1
oh man. unexpected expenses. right as i was about to send the money for the brackets.
do you mean $45 each? so $90 total. The rings are a vital part of the setup i assume?
Thanks,
Mike
Old Jun 14, 2005 | 02:23 PM
Jeff92se's Avatar
I'm needing a caw
$90 gets you 1 SET of brackets and 1 SET of centering rings.
http://forums.maxima.org/showthread.php?t=311681
Old Jun 14, 2005 | 02:52 PM
japmaxSE's Avatar
Go Get a Life!
Jeff got the Rings for me yet...
What year are those cobra wheels you have? I'm asking because I want to find out your offset?
Old Jun 14, 2005 | 02:57 PM
Jeff92se's Avatar
I'm needing a caw
No rings yet. Still 3-4 days out. The offset is 30mm about. But it's not just the offset, it's the design. So far people have run:
1) Cobra wheels me NOTE: I also run 96 Mustang GT wheels. Exact same offset but no workie. Design was diff and didn't allow the needed clearance.
2) 350z Track editions me
3) G35 Coupe wheels me and Irish
4) 17" G35 sedan wheels. Irish
4) Some TSW revos? as above.
5) I believe the 350z tourings will work. aka most 350z wheels as most G35 wheels ( I think)
6) Some are running expensive Volks TE37s or GTs.
7) Some are running SSRs but need spacers.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
