Correction Programming on AFC/AFCII
Correction Programming on AFCII Results
Quick question...I have pulled some good A/F data from my LM1 and am now ready to begin setting up the AFC. Since the AFC works in percentages of correction, is it feasible to assume that 100%=14.7:1? So if I have 11.6@3900rpm, can I simply divide 11.6/14.7 and the result would be my correction factor percentage?
Ehhh...scratch that question...I figured it out...Will post results down below so I dont start another thread for it.
There is an excel spreadsheet of my results here: http://www.ewjc.com/air-fuel-correction.zip
My beginning data read as follows:
4000 - 12.08
4200 - 11.35
4400 - 11.30
4600 - 11.17
4800 - 11.20
5000 - 11.33
5200 - 11.43
5400 - 11.46
5600- 11.35
5800 - 11.50
6000 - 11.41
6200 - 11.19
Second run after initial corrections:
4000 - 12.29
4200 - 12.50
4400 - 12.60
4600 - 12.51
4800 - 12.80
5000 - 12.73
5200 - 12.70
5400 - 12.69
5600- 12.76
5800 - 12.76
6000 - 12.73
6200 - 12.80
The third and final run after second set of corrections:
4000 - 13.10
4200 - 13.24
4400 - 13.02
4600 - 13.19
4800 - 13.24
5000 - 13.07
5200 - 12.95
5400 - 12.98
5600- 13.13
5800 - 12.99
6000 - 13.10
6200 - 12.62
I might dial up the 6200 a bit but I'm kinda more comfortable having it a little richer at that high of rpm...just kind of a safe zone. I be tunin now!!
4000 - 12.08
4200 - 11.35
4400 - 11.30
4600 - 11.17
4800 - 11.20
5000 - 11.33
5200 - 11.43
5400 - 11.46
5600- 11.35
5800 - 11.50
6000 - 11.41
6200 - 11.19
4000 - 12.29
4200 - 12.50
4400 - 12.60
4600 - 12.51
4800 - 12.80
5000 - 12.73
5200 - 12.70
5400 - 12.69
5600- 12.76
5800 - 12.76
6000 - 12.73
6200 - 12.80
4000 - 13.10
4200 - 13.24
4400 - 13.02
4600 - 13.19
4800 - 13.24
5000 - 13.07
5200 - 12.95
5400 - 12.98
5600- 13.13
5800 - 12.99
6000 - 13.10
6200 - 12.62
In response to BigLou:
I've since been told that that is a correct way to calculate it..only you don't want to aim for Stoic under load. I'm tuning for 13:1'ish' N/A & 11.5:1 under N2O for now. I used that instead of the 14.7 stoic for factoring 100%.
For spraying, I'm going to set the afc to data file number two which is still zero'd out. Then I'll pull some data of runs WHILE spraying because I have a feeling the extra fuel will change the numbers a tad towards the richer side. Then I'll tune the 2nd data file accordingly.
litch
123
Jan 4, 2024 07:01 PM
AaronL
Nov 15, 2020 11:52 AM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
