Question about our 3 cat. converters
Recently I took my car into the shop because of problems it was having, the mechanic told me that one of the front 2 cat converters is bad and needs to be replaced, and a small chance that both need to be replaced. The front 2 cat converters total around 2000$ from Nissan. What I am wondering is would it be possible to get the high flow cat. converter from custommaxima.com or does that replace the back cat. converter? Also, if it is the back cat. converter is there anything I can instal for less to fix the problem of a bad afront cat. converter. My mom said no to a Y-pipe cause the mechanic told her I could goto jail, which is BS i know, but I can't do anything about it. Anyways, what can I do, if anything? Thanks for the help.
The y pipe would be your best bet but you would have to install it yourself or have a friend do it. You would also gain some power.
If that's not an option some people have had luck hollowing out the existing pre cats in the stock y-pipe. That would solve the problem but a shop probobly wont do it.
The high flow cats sold by other companies are for the main cat only as far as I know. Most people modifying their exhaust get rid of the pre cats with a y-pipe or headers.
As long as your main cat is working you should pass emissions with an aftermarket y-pipe as long as your car is warmed up. The pre cats are only used during warm up. The worst thing that could happen would be a fine and you would have to put it back to stock. I'm not even sure if you would be fined.
You can go to a junk yard and buy the OEM part and have a muffler shop do the install so you don't get hammered. What is the car doing and why does he think the cats are bad. I would get a second opinion and not mention what the first guy said.
Originally Posted by MaximaHunty
what is the 8/80 emissions warranty?
Actually, n/m 8 years 80,000 mile.. but that sucks b/c I am at 81,xxx..
Finding a stock y-pipe and pre cats in a junk yard is a great idea. You can call around and they should be able to locate one for you.
trsandrew
Apr 8, 2016 06:45 PM
Unclejunebug
Apr 2, 2016 05:42 AM
